I've been having a problem with either my Viewsat Ultra receiver or my DP Plus Digital LNBF.My subscription service works perfectly so I'm guessing its' within the Viewsat.The FTA Tester told me to get a DP34 switch,but that didn't resolve the issue,However I would've needed one soon anyway(so thanks again FTA Tester)
I have a few questions and would appreciate some advisement if anyone has knowledge of the correct settings for a VS2000Ultra, please respond,Thank You. My questions are: #1.Should I disconnect the DP34 until I remedy the problem? #2.Are there any other files used to test the Viewsat Ultra? PFTAUSW-080104U-1.PGM/TheTotal. Viewsat_Ultr_v131.pgm/Viewsatusa. Satinfo_07.sat/viewsatusa. #3.Which sat file should the receiver display in the System Information/Receiver Information screen U006 or U007? Thank You.
