Need help
Username: Davidt487
Texas
Post Number: 62
all of a sudden my system isn't playing as loud as it once was.
ive checked everything i know to check.
the problem is even if i turn the gain up all the way im only getting 13-14 volts ac.
ive checked the rca cables they seem fine.
getting 14.9 volts dc to the amp.
i think it has something to do with my output from my eclipse cd8445. it has an 8 volt pre out and if i change to the regular rear line out nothing changes.
so im lost any help or ideas would be great?!?!
