Auto Scan
Username: Smoke74
Post Number: 103
I did a new channel scan and everything is doubled...why???
Username: Kirankumar
Kenya
Post Number: 671
you need to check your settings
Username: Bdsingleton24
Post Number: 28
I recommend using Channel Master!
Username: Smoke74
Post Number: 104
my settings haven't changed that I know of
Username: Smoke74
Post Number: 105
where do i get channel master
Username: Tapeman
New York City in-HD, NY
Post Number: 2035
doubled cuz there is 2 sets of satellites by DN
I havn't figured this out yet
But I guarantee yo it's for a major upgrade near final completion
Username: Smoke74
Post Number: 106
yeah yeah end of the world I know, but I just scanned bev and i got 824 channels and 156 music..bev have 2 sets too?
Username: Smoke74
Post Number: 107
I started deleting the doubled up channels, the receiver froze up, I turned it off at the back and when I turned it back on all my info was gone so I had to set everything back up, do another scan and again everything is doubled. How can I delete channels without it freezing up, and again I ask how to prevent the doubling of channels?
Username: Jurj1
Post Number: 411
"doubled cuz there is 2 sets of satellites by DN
But I guarantee yo it's for a major upgrade near final completion"
Funny, I did a scan, and I did not get double channels. Maybe your getting double channels because you F*UCKING IDIOTS!!!!
Username: Smoke74
Post Number: 108
thanks for the help tony...your a real piece of work
Username: Saqeeb9000
Post Number: 1353
hi smoke 74 ... tony is idiot ..don't listen to him.. do a factory reset and load the bin again and just do a normal scan... don't do a blind scan.. it should work..
Username: Juzbcuz7
Post Number: 11
Sometimes that happens. Next time delete all your channels before scannning by clicking Menu on your remote, then enter Channels (enter PIN), click delete channels, then using your remote again click the Info button. This will delete all your current channels. Now, you can do your auto scan and you will have only one set of channels.
Username: Lol
Post Number: 186
LOL tony hows it going Bud
