FTA Tester, I need your help, please
Username: Palmettolola
Post Number: 9
I appreciate all that you do to help everyone on this forum.
I tried fixing my no channels problem. I did a factory default, I have loaded the new bin (VS Lite), and loaded sat file. I am auto scanning channels and have more than one of the same channel and I still missing other channels, espn, nfl, usa, hgtv, etc. What do you suggest I do?
By the way, have I told you how much I appreciate you?
Please let me know how I can help you help me.
Thx!
Lola
Username: Saqeeb9000
Post Number: 1358
do an advanced scan...
add freq,tps etc for particular channel..
and do a channel search...
or do a blind scan...
should work..
Username: Shn
Post Number: 22
i'm new at this and a little lost. almost all my channels were taken out and i dont know what to do. i heard about a bin or file needing to be download onto my viewsat. where can i find the newest bin to download for the viewsat xtreme? do i have to pay for the bin? Pleeease help me!!!!!! thanks bye
Post Number: 1359
sharon start a new thread..
go to sat tv start new thread its option on top and then write down your problem there.. then i can help you..
Post Number: 10
Thx Sada! I do not have the option to do a blind scan. Where do I find the freq and tp for particular channels?
Post Number: 1363
so you do have an option for advance scan... where you can put freq,etc..
go to
www.l*yngsat.com there u will find freq, for particular channel etc..
Post Number: 11
my menu options are channel scan and auto scan. Txs!
