NEED BIG TIME help
Username: Parthp18
Toronto, Ontario Canada
I have a viewsat 200 ultra and i pu tin a file called ultrafailfix from dsstseters n i don noe nytin about satilite n i just put that fiel and it said no chanels den i called my friends and i did a scan for echo 7 & 3 but wen we did 3 all chanells were named by echo and i did not get sony, setmx, ajjtk and more like de desi chanels. may someone plese help! nalin anuyone cuz im new to dis place n new to my erreciver. i woul apreciate if some give me wat to do in steps , plese and thank u . happy new year n holidays.
Username: Parthp18
Post Number: 7
*2000
Username: Parthp18
Post Number: 9
and i bascily want englisha nd hindi
chanelws
Username: Nydas
Post Number: 6816
Viewsat Fail fix is a file designed to get you out of trouble if you cannot load a new BIN.
If you had looked at the HOWTO in the zipped file you would not have to ask questions.
The following is one of the sentences in there
"Will repair what appears to be an unrepairable 'dead' box..."
Wait for my next post in this thread.
Username: Nydas
Post Number: 6817
You need to go to
[link removed] and register there. Normally I would have suggested thetotalfta.com, but right now there is a contoversy.
Then goto file section and download the latest BIN for your receiver with today's date on it.
Then follow the instructions in the HOWTO file.
You will need to read for a couple of hours in the site to understand what is going on and get yourself familiar with your box.
There are no short cuts to acquiring knowledge
Username: Ke5aqn
Post Number: 3116
Nalin
you can have this one..
Username: Parthp18
Post Number: 12
ok i had changed some stuff n i don noe waht
buh not the esho
can later someone tell me wats right n worng and wat its to be on\
satilite- echo 7 119.0w
lnb power- on
lnbtype- universal
lnb high- 11250
lnb low- 9750
tp frequency- 12224
diseqc 1.0- port 2
motor- off - dont have it
lagancy sw- none
and itt has signal but no quality
satilite-echostar 3 61.5w
lnb power- on
lnb type- standard
lnb freqency- 11250
22 khz- off
tp frequncy- 12297
diseqc 1.0- port 2
motor - off - dont have it
legancy sw- none
the siggnnal is good and quality
Username: Ke5aqn
Post Number: 3122
you have both on disqc port 2 for one thing
what port is 119 connected to?
what port is 61.5 connected to?
what are your lnbs? dish pro? does it say DP?
Username: Kirankumar
Kenya
Post Number: 618
try setting your lnbs to single
Username: Parthp18
Post Number: 14
i relli AM NEW TO THIS PLACE N I HAVE NO CLUE WAHT UR TALKIN BOUT oops no caps
Username: Nydas
Post Number: 6826
Usually 61.5 is connected to Port 3 or 4 and the 119 to 1 and 110 to 2.
Username: Ke5aqn
Post Number: 3125
how is this connected?
Username: Nydas
Post Number: 6828
Parth: You must respond to suggestions given.
I had asked you to read the howto from ultrafailsafe. Did you?
Did you load the latest BIN from ftatalk.com?
Kenya
Post Number: 620
Parth,
we want to help you but only if can stay on one thread and NOT start multiple threads.now do u understand what Nalin is saying,if not tell us which part you don't understand so we can help you.
STAY ON THIS THREAD ONLY
Username: Parthp18
Post Number: 15
k my 61.5 is on #1
and the other 119 is on #2
Username: Ke5aqn
Post Number: 3153
Cool adjust the antenna settings to represent that.
Username: Parthp18
Post Number: 16
buht waht do i do i dont gewt becuz my reciver is new can u give it step by step
Username: Ke5aqn
Post Number: 3155
I have a appointment with a customer so I cant sit here and hold your hand through this...using your remote set all fields in your antenna settings to match how the antenna is connected to your receiver.
good luck hopefully nalin has more time now
Username: Aright
Get a spoon.
Kenya
Post Number: 629
Parth,
how did you get to this section?
buh not the esho
lnb power- on
lnbtype- universal
lnb high- 11250
lnb low- 9750
tp frequency- 12224
diseqc 1.0- port 2
lagancy sw- none
lnb power- on
lnb type- standard
lnb freqency- 11250
22 khz- off
tp frequncy- 12297
diseqc 1.0- port 2
legancy sw- none
go there again,i see that you have both set on port 2.you need to change 61.5 to port 1,
try this and if you need more help then post on this same thread
Username: Parthp18
Post Number: 17
Afrcian it works now all becuz of u yayayaayayayya thanks man!
Kenya
Post Number: 649
you are welcome buddy
Username: Parthp18
Post Number: 18
but my favorite gruops are attached like there is no group for hindi kids and ppv. is there a bin that its like the same settings as before
Username: Ke5aqn
Post Number: 3266
You are talking about a channel list not a bin. It is best if you have set up all your fav in list's like that to have a backup of your channel list on your computer. I have the instructions on how to do that in my guide..
