Username: Afaizi Post Number: 46 Registered: Sep-06
Saturday, January 05, 2008 - 22:24 GMT Hey I had a question whether I can use the same wire that I use to load a file to my Fortec Lifetime Ultra to my Pansat 2700 or do I need a different wire for the Pansat receiver. Any feedback would be greatly appreciated. Thanks
Username: Kirankumar Kenya
Post Number: 692 Registered: Oct-07
Saturday, January 05, 2008 - 22:29 GMT afaizi, try using it,if it does not work then it is not going to do any harm if it doesn't work post here so we can help.good luck
Username: Tale Post Number: 120 Registered: Sep-07
Saturday, January 05, 2008 - 23:07 GMT Pansat 2700 uses null twisted serial cable ...so it's different !
Username: Jagr1234 Post Number: 146 Registered: Nov-07
Saturday, January 05, 2008 - 23:13 GMT i use same serial cable for both flu and 2500 never any issues
