Can someone plese help me vs-ultra
Username: Parthp18
Toronto, Ontario Canada
i downloaded the bin ultrafix from dss testers and i put it in my reciver then it said no chaneels i even tried later to put in the latest file like right now. and i used usb cuz i don have the port from the back of my computer. may someone plese help and thank u . happy new year n holidays
Username: Prar69
Post Number: 103
Do you have signal and quality?
Check yuor LNB settings, make sure it is at Standard or Universal
Also, turn the reciever off for 10 seconds (from the back) and back on
Username: Scabz
Knoxville, Tn Us
Post Number: 247
What is the name of the new fix. Make sure you didn't load the wrong one.
Username: Ke5aqn
Post Number: 3094
Hello,
I made a guide to help users not have this happen to them. What has happened is during the update process your receiver lost data. You will need to adjust all antenna settings correctly, then blind scan each satellite you can receive..
https://www.ecoustics.com/electronics/forum/home-video/428318.html
Username: Parthp18
uhmm yo no signal or quality and my eecho things are on echostar 7 and 3. and i don get waht the echo star things are to be obn like lnb power n stuff. uhh i downloaded a bin from dss testers called ultra fix n then wen i put the file in the reciver it said no chanels
Username: Ke5aqn
Post Number: 3099
parth,
read my guide
Username: Blazinflames
Post Number: 15
i tried that tutorial i put new sat file the new bin PFTAUSW-080104U-1.PGM and everything i dont understand i get signal 24 and no quality there another problem. I even did factory default
Username: Ke5aqn
Post Number: 3103
factory defalt removes all channels and antenna settings.
what is your set up? what is connected to the receiver...lnb,switch..is the lnb a dish pro?
Post Number: 16
I have a lnb connected i use 61.5 and 119
Post Number: 17
it not the lbn or anything the problem is since i insall that new bin last time it screwed up everything.... i just DON'T get signal or qualiity anymore.
Username: Ke5aqn
Post Number: 3106
Harry,
are you sure you have a current working transponder for the satellite you are trying to receive?
http://www.lyngsat*com/ has the transponders for each sat
Post Number: 18
Yes iv been using 119w and 61.5
Username: Prar69
Post Number: 104
Check your antenna settings. Make sure all is the way it shoudl be, Ports, LNB, ...
This happened to me before, a new bin changed my Antenna settings for some reason.
Username: Parthp18
k now i did a antina and auto scan for echo 3 buh no desi chanles came like sony. zee soports n now all its doin is atoroll
Username: Ke5aqn
Post Number: 3108
Parth,and Harry
be sure the antenna is pointed at the correct sat. an example your receiver is looking at 110 but trying to get a channel on echo 3 it will read autorolling and never get the channel..that is why everone keeps saying look at your antenna settings...
might want to disconect the other lnb while setting up each sat. then conect the switch after you get all the correct channels
Username: Moddy
Post Number: 18
Hi guys,I will really appreciate if someone will come with the new year blessings, actualy I was having lifetime Ultra and convaerted to Pansat 2007A,recently I have download a new bin (x-87b1-080102-b75-235-ap1-fixed-zip)with autoroll off I put new keys and blind scan after all the hard work I am only gettin "W" channels no PPV no nothing, I know we have very kind people here can anyone assist me pls???? I will apprecite if it will be step by step cos I am new on this thing.
Username: Parthp18
ye i noe my reciver wne i did echo 7 it was sayin 119.0w then wen i was doing echo 3 the it said 61.5 buh wen i did my echo 3 i diddnt get hindi chanels and it isnt goruped like in kids , hindi, movies, ppv
Username: Parthp18
yes may i have step to srtep aswell becuz im new to teh reciver and this place
Username: Moddy
Post Number: 20
Username: Ke5aqn
Post Number: 3110
moddyb
you need to make a new thread.
Username: Moddy
Post Number: 23
Username: Moddy
Post Number: 24
Thanks "THE FTA TESTER" but what is the new thread? and how to do it.
Username: Nydas
Post Number: 6815
moddy: I have started new thread and replied.
https://www.ecoustics.com/electronics/forum/home-video/430722.html
Username: Parthp18
Post Number: 8
anyone plese help me
Post Number: 19
Omfg lol i need help my dish hasn't worked for like 2 week noe everything is good but my dish isnt catching the signal and quality
Username: Ke5aqn
Post Number: 3115
harry,
go to the menu for antenna settings and post what you have their..
parth,
your post are hard to understand try again..
Username: Parthp18
Post Number: 10
ok
Username: Nydas
Post Number: 6818
TFT: I have started with Parth Patel in another thread.
Username: Ke5aqn
Post Number: 3117
thank you!
Username: Parthp18
Post Number: 11
ok i had changed some stuff n i don noe waht
buh not the esho
can later someone tell me wats right n worng and wat its to be on\
satilite- echo 7 119.0w
lnb power- on
lnbtype- universal
lnb high- 11250
lnb low- 9750
tp frequency- 12224
diseqc 1.0- port 2
motor- off - dont have it
lagancy sw- none
and itt has signal but no quality
satilite-echostar 3 61.5w
lnb power- on
lnb type- standard
lnb freqency- 11250
22 khz- off
tp frequncy- 12297
diseqc 1.0- port 2
motor - off - dont have it
legancy sw- none
the siggnnal is good and quality
Username: Nydas
Post Number: 6822
Parth: Continue the conversation in the other thread from where I stopped, for me to have a continuity.
Username: Ke5aqn
Post Number: 3121
you have both on disqc port 2 for one thing
what port is 119 connected to?
what port is 61.5 connected to?
what are your lnbs? dish pro? does it say DP?
Username: Parthp18
Post Number: 13
i don noe waht u mean im new to this place man
Username: Ke5aqn
Post Number: 3124
the switch------it looks like this
how is it connected?
Username: Kirankumar
Kenya
Post Number: 619
Parth,
we want to help you but please do NOT start multiple threads.
Username: Nydas
Post Number: 6830
For Parth - Stay in " NEED BIG TIME help" thread.
Username: Ke5aqn
Post Number: 3127
African,
Nalin did that to help him easer
I am about to take a break...for a month LoL
Kenya
Post Number: 621
FTA,
stay on the other thread,this guy needs some help.thanks
Username: Moddy
Post Number: 25
Although I didnt solve my problem but I am glad to say that if we got 3 "Nalin Nyda" in this forum we will be having no problem, hes trying his best to help everyone.
