nalin i didnt intend to spam just needed some help and asked a question. and i got some help and some answers from fan of viewsat and tab mak. thanx fellas.
Help anyone, VS2000 lite, DN. My channels are delaying about 15 seconds when there changed. I was going to try to input the keys manually but i go to menu/user setting/then i press ok on code menu and nothing happens it stays at the user setting menu. Never has happen before... Thanks
TFT, the new bin has it's issues (channels Delay). I don't know if there is gonna be another fix for this .any way I did read from another blog that if downloaded the OPKEY kinda helps on the delay issue It could Just BS. if so do you know where can I get the latest OPKEY. Thanx
thaT is BS all a opkey does is input the correct keys would have nothing to do with the delay I would think...just have a nice grill cheez sandwich and watch tv..
All files for all boxes have their issues of channel delay, the elapsed time differs from a box type to another with the greatest for both VS and CW. Waite a new fix to the problem will be released soon.
One way to seperate a site from the spam list is to PM it to someone looking for a file. Other than that if you post a site to draw ppl as does FTAVIEW, your a spam site so for those looking for spam sites then you have alot to choose from, for those looking for true trusted sites, see FTTESTERS guide there is only the rusted sites listed.
