Bronze Member Username: Ehsankhan777Post Number: 29 Registered: Jun-06 | I have a plat lite everytime i create favorites and add channels after a little while they would be gone I can not choose the fav when pressing the button i can not even go back scan again. can anyone please help me with this |
Gold Member Username: NydasPost Number: 6880 Registered: Jun-06 | This BIN will last a few more hours. New BIN incorporating BEV should hopefully correct your problems. |
Bronze Member Username: Ehsankhan777Post Number: 30 Registered: Jun-06 | Thanks does it matter even if i'm only using the dn channels |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3182 Registered: Sep-06 | OK I will say it to you like this. The plat has never worked as it should when you try to make a channel list with favorites by using the receiver to do so. I have had much better luck useing OSDEdit 1.6 - Channel Editor to do that. You can get OSDEdit 1.6 - Channel Editor from [link removed] what you do is useing the loader program get the channel list from the receiver to the computer. Then use the OSDedit program to edit the list, make fav's all that...then install the channel list back to the receiver after your done... Thats how I do it and have had great luck. Their is another popular program called channel ,master but it is not viewsat friendly...it does the same thing as OSDEdit so just use it. |
Bronze Member Username: Ehsankhan777Post Number: 31 Registered: Jun-06 | Thank You I will try that and let you know of the outcome |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3183 Registered: Sep-06 | You should go and make your channel list so you will have it to put in after you update next time...like in my guide |
Bronze Member Username: Ehsankhan777Post Number: 33 Registered: Jun-06 | Thanks but i can not download it from the stb to pc via serial. it does not connect when adding new bin to stb all i had to do was keep the receiver off and then start the upload to stb then turn on the reciever but this trick did not work when i tried it from stb to pc |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3262 Registered: Sep-06 | Ehsan on my new updated guide I have instructions on how to send the files from the receiver to the host computer. here is a link to the newer guide https://www.ecoustics.com/electronics/forum/home-video/431069.html |
