Hi, I have Pansat 2700 and 2800 both of 'em with newest files, but all Im gettin' is "scrambled or bad channel" smetimes got "No signal". Since I've input new files also have problem with low signal quality. So I have to play with antena settings to get signal (which I never had problem in the past) Once I got signals all I'm getting is those messages. Help, anyone?
1. Recheck you /TV setup for date/time 2. Turn autoroll and closed captions off 3. Set up favourties. 4. Use EPG button within favourites to change channels.
You will have to restart with 1. Load appropriate BIN - jvvh_235 or CS_235t_lightning 2. Do "Default settings" 3. Recheck your TV setup for date/time 4. Turn autoroll on and closed captions off 5. Do Power Scan. DO NOT USE CHANNEL MASTER FOR CHANNELS. 6. Turn autoroll off. 7. Set up favourties. 8. Use EPG button within favourites to change channels.
Ok guys, thanks for helping me . Here's the deal, pansat 2700 clone is connected to dishplus antena, and 2800A is connected to sepurate dish which was profesionally installed manny years ago(it's 18" dish I guess) so I have no idea which lnb's I'm using. In my settings I always input as "standard Lnb" never had a problem 'till now. I've tried everything i know and everything you guys said, nothing helps. I even reloaded bins few times.
