A Great Deal ! ?
Username: 1tina_chick
Post Number: 143
A HDMI HD Box for $199 Neusat 9000 HD -What about Support ?
What does everyone think ? A GREAT BOX or What ?
A USB programmable, Free To Air, Digital Satellite Receiver that can be accessible to over 120 satellites receiving over 6000 television and radion channels.
A receiver that is fully MPEG 2 / DVB Compliant with Picture-In-Graphic functions, multi-Picture (4,9,10,13 or 16 pictures), and the most comprehensive multi-language support in the industry.
Sti7710 200Mhz Processor chip
SDRam 128mb memory
8mb Flash memory
S/W upgrade and download through USB 2.0
USB Memory Stick Interface
USB PVR Function
HDMI
YPbr Component S-Video & Composit video
Smart Card reader
DVB-S fully compliant
On Screen Display with 256 color
Blind Search(Power Scan)
Powerful search CH.(Power Scan)
Powerful search function :Automatic,Manual(PID) & TP search
Multi-Satellite & TP Search
Powerful EPG: 7days program guide
SPDIF Digital Sound
DiSEqC 1.0& 1.2 compatible and ULSALS supported
8 Favorite Channel Groups
Multi language supported (OSD&Menu)
Total 5,000 channels
Multi Pictures Function(4~16pictures)
True 16:9 widescreen
AC-3 Digital Sound
(VFD)Vacuum Fluorescent Display on the front panel
1 Year Warranty.
Username: Saqeeb9000
Post Number: 1337
tina if its not working all the time then it's not worth to buy it ..
buy nfusion up 90% of time
Username: Ke5aqn
Post Number: 3196
I know nothing about them...tried to look at them found very little support....
I bought a nfusion
good luck
Post Number: 1340
c0st $ 220 (spend $ 20 more )... its worth it..
Post Number: 144
Thanks Boys, Best bang for Buck in this price HD,What da ya think ?
Post Number: 1343
support with HD sonicview 8000 (hd)+ u have to pay extra to buy an adapter in order to watch dn hd (up 75% of time).. most of time they have bin's fist..
without hd .. nfusion best choice..(up all the time)
Post Number: 145
I like the views*t Pro's price and features but I need HD in this price range, any ideas ?
Post Number: 1349
so is it support or price?
Post Number: 146
Both - Bang for Buck (HD) I'm still shopping what a Girl does best !
Username: Ke5aqn
Post Number: 3225
I as well have a wonderfull HDTV .
I spend a few DAYS looking at hd receivers way to high at the moment..and decided to wait. I got a NFUSION instead. I can get abc, cbs, anf fox here with my OTA antenna so its cool for now..
Post Number: 149
Thanks FTA I Know OTA Looks GREAT ! - In HD -
AS you know, HD Boxes now around 2 Bills but which one ?
Username: Ke5aqn
Post Number: 3234
a HD box with good support is not 200 more like $700$
I am gonna wait
Post Number: 151
2 Much for me I like the ones i've seen for 2 bills
Username: Ke5aqn
Post Number: 3238
what brands are you seeing for $200? Lets go read some reviews n them...see how good the support is
Post Number: 152
Neusat and others
Username: Ke5aqn
Post Number: 3241
Neusat is a great receiver I almost went that way myself but, never found the correct forum for support.
It is complex and uses IKS like the nfusion has to connected to the nett at all times...
Post Number: 153
I like the views*t Pro's price and features - USB, fast chip, RGB,
Hard drive via USB , massive RAM and Great support - Right ?
What % does it go down vs Up time
Username: Ke5aqn
Post Number: 3247
same as all other regular FTA receivers last few weeks 50%
it is not a HD receiver
nfusion is 99% working and it also is a dvr if set up to be..
