Silver Member Username: Lol
Post Number: 175 Registered: Sep-06
Posted on soon within minutes |
Bronze Member Username: Juventus
Post Number: 17 Registered: Dec-07
Posted on don't count on it |
Bronze Member Username: Xsmoker
Elderbank,
Nova scotia
Post Number: 23 Registered: Dec-07
Posted on have a little fath in the coders I guess! |
Post Number: 177 Registered: Sep-06
Posted on Confirm extreme file DBPSW-080105X.PGM works on Bev Plat file was released also with bev fix |
Bronze Member Username: Bernardmi
Post Number: 39 Registered: Dec-07
Posted on And I confirmed it works fine on Lite. There is a 30 second delay between channel change however. |
Post Number: 178 Registered: Sep-06
Posted on extreme is here http://www.savefile.com/files/1303254 Platinum is here http://www.savefile.com/files/1303251 |
New member Username: Xmikex_1983
Post Number: 1 Registered: Jan-08
Posted on does anyone know what could be causing my vsextreme to be goin on and off once i dl the new fix?? it turns on and off every 5 seconds. |
Gold Member Username: Asharfi
Post Number: 1714 Registered: Aug-06
Posted on All files are out and all are working fine .. no need to wait .... |
Silver Member Username: Leafs
Post Number: 316 Registered: Oct-07
Posted on all viewsat files are now posted at www.ftasolutions,blogspot.com |
Silver Member Username: Birdwatcher
Post Number: 637 Registered: Jul-06
Posted on i havent downloaded the most recent file for extreme, is it worth it or is still taking long to change channels? |
