Please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Username: Guanajuatos_best
Post Number: 127
i'm only geting 300 channels on my xtreme after blindscan. pointing at 110 and 119.
please and thanks
Username: Saqeeb9000
Post Number: 1320
try to do a factory bin and reload the bin ..
Post Number: 128
do you think that 75% of signal strength and quality affects this?
Username: Lol
Post Number: 164
never Blind scan thats for FTA channels only
Post Number: 129
so then how do i get channels????
Post Number: 1323
try to load a factory bin and reload the bin
Username: Lol
Post Number: 165
autoscan one sat at a time
in settings disable lnb to other sats and scan one at a time re-enable Lnb when complete
Username: Lol
Post Number: 166
if you scan and end up with dupes disable auto scan and delete the dupes then re-enable autoscan
Username: Lol
Post Number: 167
your making this chit 1000 times harder than it is
Post Number: 130
Paul:
will try.
but i was not able to disable other lnb to other sats. you said that in settings but i was not able to find how.
Username: Lol
Post Number: 169
the only paisa:: in settings antenna settings / LNB power just turn it off
turn one LNB or sat on at a time autoscan then save then turn it off move to next sat turn LNB power on autoscan save then repeat
no since scanning bev since it doesn't work with this bin
Username: Lol
Post Number: 170
after done scanning make sure you turn Lnb power back on of course :-)
Post Number: 131
all right thanks.
it had been a while since i did not scanned channels and it seems that i'm forgetting things.
Post Number: 132
one last thing to erase the duplicates can i use channel master and just click erase duplicates?
thank you very much
Username: Scabz
Knoxville, Tn Us
Post Number: 250
I always use autoscan and after that I rescan some tp's.
Username: Psychmonster
Rhodium MemberAint nuthin ...
Post Number: 456
thats 300 channels more than u got 2 days ago...chill out pleasssses!!!!
Username: Lol
Post Number: 172
channel master is for morons
turn off autoscan delete your dupes save then re-enable autoscan
Post Number: 133
it sure is more than before.
thanks
Username: Lol
Post Number: 173
if you have massive dupes do a factory default then install latest bin reset your settings
(remeber the settings // take digital photo of settings screen if you need too // )
and do your scans
Username: Madflea168
Post Number: 8
in the menu where antenna setup, when you try to do the 110 or 119, make sure the upper corner do showed the SAT ID you receive, otherwise you will not get the right channels.
Username: Ke5aqn
Post Number: 3192
stop stop stop
I made a guide for this!! located https://www.ecoustics.com/electronics/forum/home-video/428318.html
next time save yourself all this time and fallow that.
now what is your lnb? is it a dish pro? the way you are decribing the trouble is what a dish pro will do with the wrong settings or a switch added to it
please list your set up
Post Number: 134
yup. using Dish Network Dish Pro Twin LNB
Username: Ke5aqn
Post Number: 3214
ok do you have a disqc switch on it too?
we are getting very close to having your receiver fixed
Post Number: 135
nope. only the one with the lnb's
Username: Ke5aqn
Post Number: 3218
you mean the one inside the lnb? or is their a switch mounted near the lnb
Post Number: 136
the one inside
Username: Ke5aqn
Post Number: 3221
ok cool and its just one dish 500 right?
how do you have the antenna settings?
Username: Fortec01
Post Number: 124
does any1 know if there is a bin out there for fortec ultra
Username: Ke5aqn
Post Number: 3224
cannon,
I answered you in another thread all I am willing to tell a user that hijacks a thread.
thanks
Post Number: 137
FOR 119
LNB POWER= OFF
LNB TYPE UNIVERSAL
LNB HIGH=11250
LNB LOW=11250
TP. FREQ.= 1224
DISEQC 1.0= PORT1 (PORT2 FOR 110)
MOTOR=OFF
LEGACY SW=NONE
all settings are the same for both satellites. only the port for diseq change.
an how about we continue this tomorrow. have to wake early tomorrow and i really need some sleep.
thanks
Username: Ke5aqn
Post Number: 3226
ok cool I was gonna tell you
that is correct but
i have one here that likes the tone burst better so play with the disqc settings....try 3 and 4 then the tone burst....something will work
let me know I will be in and out
