ZX 650.4 Kicker
Username: Tpa954
Hollywood, Florida U.S.A
Post Number: 87
I jst bought a kicker zx 650.4 with a two year warranty off ebay for 115.00 . I was wondering how will i set this amp since my door speakers can only push 100 in the front each and 150 in the back each . Any suggestion
Username: •cam•
BC Canada
Post Number: 1454
They can only handle about 100W and 150W.
Just set the gains for 100 from both the front and rear channels. You'll want to turn the rear down, anyway. Unless you low-pass them to act as "sub" woofers.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5097
no need for rearfill..
Username: •cam•
BC Canada
Post Number: 1476
I figure if he has them, he might as well keep 'em. Proper adjustment can make it sound fairly good.
Username: Tpa954
Post Number: 97
You think it will be better if i run them like a subwoofer ???
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1033
It would be better if you had a subwoofer and got rid of them.
Username: •cam•
BC Canada
Post Number: 1485
True.
Are you interested in a sub stage, or do you just want to amp these speakers you have?
Username: Tpa954
Post Number: 110
Just amp them i decided to just run them like a sub
