Silver Member Username: Guanajuatos_bestPost Number: 127 Registered: Jul-07 | i'm only geting 300 channels on my xtreme after blindscan. pointing at 110 and 119. please and thanks |
Gold Member Username: Saqeeb9000Post Number: 1320 Registered: Oct-07 | try to do a factory bin and reload the bin .. |
Silver Member Username: Guanajuatos_bestPost Number: 128 Registered: Jul-07 | do you think that 75% of signal strength and quality affects this? |
Silver Member Username: LolPost Number: 164 Registered: Sep-06 | never Blind scan thats for FTA channels only |
Silver Member Username: Guanajuatos_bestPost Number: 129 Registered: Jul-07 | so then how do i get channels???? |
Gold Member Username: Saqeeb9000Post Number: 1323 Registered: Oct-07 | try to load a factory bin and reload the bin |
Silver Member Username: LolPost Number: 165 Registered: Sep-06 | autoscan one sat at a time in settings disable lnb to other sats and scan one at a time re-enable Lnb when complete |
Silver Member Username: LolPost Number: 166 Registered: Sep-06 | if you scan and end up with dupes disable auto scan and delete the dupes then re-enable autoscan |
Silver Member Username: LolPost Number: 167 Registered: Sep-06 | your making this chit 1000 times harder than it is |
Silver Member Username: Guanajuatos_bestPost Number: 130 Registered: Jul-07 | Paul: will try. but i was not able to disable other lnb to other sats. you said that in settings but i was not able to find how. |
Silver Member Username: LolPost Number: 169 Registered: Sep-06 | the only paisa:: in settings antenna settings / LNB power just turn it off turn one LNB or sat on at a time autoscan then save then turn it off move to next sat turn LNB power on autoscan save then repeat no since scanning bev since it doesn't work with this bin |
Silver Member Username: LolPost Number: 170 Registered: Sep-06 | after done scanning make sure you turn Lnb power back on of course |
Silver Member Username: Guanajuatos_bestPost Number: 131 Registered: Jul-07 | all right thanks. it had been a while since i did not scanned channels and it seems that i'm forgetting things. |
Silver Member Username: Guanajuatos_bestPost Number: 132 Registered: Jul-07 | one last thing to erase the duplicates can i use channel master and just click erase duplicates? thank you very much |
Silver Member Username: ScabzKnoxville, Tn Us Post Number: 250 Registered: Oct-07 | I always use autoscan and after that I rescan some tp's. |
Silver Member Username: PsychmonsterRhodium MemberAint nuthin ... Post Number: 456 Registered: Jul-06 | thats 300 channels more than u got 2 days ago...chill out pleasssses!!!! |
Silver Member Username: LolPost Number: 172 Registered: Sep-06 | channel master is for morons turn off autoscan delete your dupes save then re-enable autoscan |
Silver Member Username: Guanajuatos_bestPost Number: 133 Registered: Jul-07 | it sure is more than before. thanks |
Silver Member Username: LolPost Number: 173 Registered: Sep-06 | if you have massive dupes do a factory default then install latest bin reset your settings (remeber the settings // take digital photo of settings screen if you need too // ) and do your scans |
New member Username: Madflea168Post Number: 8 Registered: Jan-08 | in the menu where antenna setup, when you try to do the 110 or 119, make sure the upper corner do showed the SAT ID you receive, otherwise you will not get the right channels. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3192 Registered: Sep-06 | stop stop stop I made a guide for this!! located https://www.ecoustics.com/electronics/forum/home-video/428318.html next time save yourself all this time and fallow that. now what is your lnb? is it a dish pro? the way you are decribing the trouble is what a dish pro will do with the wrong settings or a switch added to it please list your set up |
Silver Member Username: Guanajuatos_bestPost Number: 134 Registered: Jul-07 | yup. using Dish Network Dish Pro Twin LNB |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3214 Registered: Sep-06 | ok do you have a disqc switch on it too? we are getting very close to having your receiver fixed |
Silver Member Username: Guanajuatos_bestPost Number: 135 Registered: Jul-07 | nope. only the one with the lnb's |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3218 Registered: Sep-06 | you mean the one inside the lnb? or is their a switch mounted near the lnb |
Silver Member Username: Guanajuatos_bestPost Number: 136 Registered: Jul-07 | the one inside |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3221 Registered: Sep-06 | ok cool and its just one dish 500 right? how do you have the antenna settings? |
Silver Member Username: Fortec01Post Number: 124 Registered: Sep-06 | does any1 know if there is a bin out there for fortec ultra |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3224 Registered: Sep-06 | cannon, I answered you in another thread all I am willing to tell a user that hijacks a thread. thanks |
Silver Member Username: Guanajuatos_bestPost Number: 137 Registered: Jul-07 | FOR 119 LNB POWER= OFF LNB TYPE UNIVERSAL LNB HIGH=11250 LNB LOW=11250 TP. FREQ.= 1224 DISEQC 1.0= PORT1 (PORT2 FOR 110) MOTOR=OFF LEGACY SW=NONE all settings are the same for both satellites. only the port for diseq change. an how about we continue this tomorrow. have to wake early tomorrow and i really need some sleep. thanks |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3226 Registered: Sep-06 | ok cool I was gonna tell you that is correct but i have one here that likes the tone burst better so play with the disqc settings....try 3 and 4 then the tone burst....something will work let me know I will be in and out |
