Username: Leo_here Post Number: 26 Registered: May-06
Saturday, January 05, 2008 - 00:34 GMT Hi guys..I am having problem scanning channels 584 (Sahara Samay), 585 (Aaj Tak), and 586(Headlines Today) on 61.5 with my Viewsat Platinum. Can anybody help me out?
Username: Madflea168 Post Number: 6 Registered: Jan-08
Saturday, January 05, 2008 - 03:50 GMT make sure your antenna is setup to the correct port in the menu and have the signal/quality and save it before you exit and scan.
Username: Ke5aqn IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 3186 Registered: Sep-06
Saturday, January 05, 2008 - 03:54 GMT Did you install a fresh satfile when you updated? we have been seeing here the viewsat losing data during the update process...
Username: Scabz Knoxville,
Tn
Us
Post Number: 254 Registered: Oct-07
Saturday, January 05, 2008 - 04:35 GMT Tester I never install factory bin before new bin install and my ultra works fine. Now when I do install factory first and then the new bin I loose all my channles. So, rather than loosing all my channles i just install new bin . It works for me.
I WILL FIND...
Post Number: 3201 Registered: Sep-06
Saturday, January 05, 2008 - 04:45 GMT scabz please do not try to condirdict my post without reading it first! no were in any of my post or guide do I say install a factory bin....i advise to install a fresh SATFILE and you channel list! we have threads all over the place with users that did not do as my guide and are having trouble...
Username: Xdetoursx Post Number: 12 Registered: Dec-07
Saturday, January 05, 2008 - 04:49 GMT The way I fixed mine was by throwing it in the trashcan. Viewsat blows nut.
I WILL FIND...
Post Number: 3245 Registered: Sep-06
Saturday, January 05, 2008 - 07:02 GMT viewsats are great you just have to upload correctly and they work great!
Username: Leo_here Post Number: 27 Registered: May-06
Saturday, January 05, 2008 - 07:42 GMT I am getting all the other channels available on 61.5..Just having problem in getting the three I mentioned (584,585 and 586) Mad I learned alot from this site about ports and settings and thanks for your input but the only issue I am having is with these 3 channels. Do I have to scan a specific TP and how?
Username: Zigziga Post Number: 1 Registered: Jan-08
Saturday, January 05, 2008 - 07:47 GMT Leo, did do a hard boot (from the back botton) after downloaded the new bin. or maybe need to scan the 61.5 again.
Username: Leo_here Post Number: 28 Registered: May-06
Saturday, January 05, 2008 - 08:09 GMT I have tried everything Installing factory bin then loading the latest bin Installing satinfo file again Hard booting again and again befre scanning. I scanned it like 100 times and got all the other channels but still no luck. Like I said the issue is with only 3 channels.It's not like the receiver have some problem as I used to get these channels before with the same receiver I have now.Its just that I didnt use it for a long time because I was using Captive Works.
I WILL FIND...
Post Number: 3249 Registered: Sep-06
Saturday, January 05, 2008 - 08:12 GMT sorry your having so much trouble give me again the 3 missing channels I will go see whats up
Username: Leo_here Post Number: 29 Registered: May-06
Saturday, January 05, 2008 - 08:25 GMT 584 (Sahara Samay), 585 (Aaj Tak), 586(Headlines Today)
I WILL FIND...
Post Number: 3253 Registered: Sep-06
Saturday, January 05, 2008 - 08:35 GMT 584 Sahara--is on 148 transponder 12574 585 Aaj----is on 148 transponder 12574 586 headlines---is on 148 transponder 12574 here on my receiver and all working 100%
I WILL FIND...
Post Number: 3254 Registered: Sep-06
Saturday, January 05, 2008 - 08:36 GMT I cant get 61.5 a house blocks anything east of 82 for me so I dont know they may be their as well
I WILL FIND...
Post Number: 3255 Registered: Sep-06
Saturday, January 05, 2008 - 08:40 GMT According to http://ekb.dbstalk.com/61-5list.htm the 3 channels are their
I WILL FIND...
Post Number: 3256 Registered: Sep-06
Saturday, January 05, 2008 - 09:06 GMT Ok found them useing my buddy's dish on 61.5 584---transponder 12384 585--transponder 12384 586--transponder 12384 all working 100%
Username: Ehsankhan777 Post Number: 32 Registered: Jun-06
Saturday, January 05, 2008 - 15:12 GMT I had the same problem what i did was checked my lnb settings i had it on single then changed it to dp and scanned it again it picked up everything
