Bronze Member Username: JerkislandPost Number: 70 Registered: Mar-07 | I loaded the new bin file and channel file for viewsat extreme, though it said everything succesfully I get no channel displayed on the receiver. I had to do a blind scan to get the channels, can someone tell what might be wrong that I didn't get the channels when I loaded the CHA file along with new bin file? |
Gold Member Username: Saqeeb9000Post Number: 1344 Registered: Oct-07 | i think ftatester is tired of this... here is what to do by ftatester.. https://www.ecoustics.com/electronics/forum/home-video/428318.html |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3198 Registered: Sep-06 | sure just like did for you last time... I made a guide for you! Next time do what it say's and in 5 min you will watching tv, eating popcorn enjoying life and not looking at a receiver with no channels |
Bronze Member Username: JerkislandPost Number: 71 Registered: Mar-07 | Sada Bhai, I tried exact same steps but even though Channel file (*cha) is succesfully downloaded, I still don't see the channel list. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3200 Registered: Sep-06 | you missed something.....cheak the cha file useing osdedit |
Gold Member Username: Saqeeb9000Post Number: 1347 Registered: Oct-07 | are u getting signal right... did u check your port setting every thing is correct? |
Bronze Member Username: JerkislandPost Number: 72 Registered: Mar-07 | FTA Tester, I opened the file using OSEDIT and it successfully opened and I see all my favourites but when I download it on my receiver I don't see the channels at all. |
Bronze Member Username: JerkislandPost Number: 73 Registered: Mar-07 | Signal is more 90%, port setting is set to COM1 and baud rate to 115200. After doing blind scan I get all the channels. |
Gold Member Username: Saqeeb9000Post Number: 1348 Registered: Oct-07 | After doing blind scan I get all the channels. ? |
Bronze Member Username: JerkislandPost Number: 74 Registered: Mar-07 | Yes I get all the channels and then i have to sort them again.I wanted to avoid to do the blind scan by creating the SAT file and Channel file but that didn;t work as when I loaded Channel file though it was successfull I didn;t get my channels or favourites. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3207 Registered: Sep-06 | just do a factory reset, and put the satfile and channel list in from the computer....easy |
Bronze Member Username: JerkislandPost Number: 75 Registered: Mar-07 | Did that too and same result. I guess may be the channel file and uploaded from STB to PC was not done right. Hence I will do it again using OSEDIT. Going by the rate of ECM I am sure it will come handy. Thanks for the help FTA Tester and Sada Bhai. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3210 Registered: Sep-06 | i dont get it you used the loader program to install the channel list into the receiver? |
Bronze Member Username: JerkislandPost Number: 77 Registered: Mar-07 | Yes I used Loader 2, loaded the bin file and then loaded the channel file and hit PC -> STB. The download was successfull. When i turned on the reciever I saw that the new bin was there but I was not seeing any channels (and Favorites I created). |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3213 Registered: Sep-06 | ok for some reason the list did not "take" oh and you forgot the satfile! factory reset, new bin, satfile, channel list, make popcorn, watch tv |
Bronze Member Username: JerkislandPost Number: 79 Registered: Mar-07 | Also when I edit the cha (Channel) file in OSEDIT I see all my favourites and the channels listed under the favourites. |
Bronze Member Username: JerkislandPost Number: 80 Registered: Mar-07 | Do I upload the SAT file from STB -> PC in the same way I did for the channel file ? |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3219 Registered: Sep-06 | go get a fresh one from viewsatusa.com its on their support page |
Bronze Member Username: JerkislandPost Number: 81 Registered: Mar-07 | Thanks got it from viewsatusa.com. Thanks for your help. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3228 Registered: Sep-06 | cool no problem... |
