Bronze Member Username: Legend_killer
Post Number: 38 Registered: Mar-06
Posted on is there a way to prevent freezing on viewsat lite, channels load after nearly 10 secs... i read like doing factory default or something? |
Gold Member Username: Ke5aqn
IF I DONT KNOW THE ANSWER,
I WILL FIND...
Post Number: 3232 Registered: Sep-06
Posted on no no no no factory reset will delete all settings and channels all plat are doing it hopefully with next bin it will be fixed....you have to live with it |
Post Number: 39 Registered: Mar-06
Posted on oh ok so there is no fix. thanks |
