Bronze Member Username: RbhoopPost Number: 25 Registered: Jun-06 | Pulling my hair out have a flu but not sure if i can use a pansat file or not and how can you tell if you have a straight cable or null |
Gold Member Username: RtapFL Post Number: 1566 Registered: Jan-07 | ron use straight cable rs232 db9.and no you can not use pansat bins for converted flu. |
Gold Member Username: NydasPost Number: 6877 Registered: Jun-06 | If you have a FLU, either you accept the limitation of basic viewing with a 2393T or 294T BIN or you convert to a Pansat 2700 work-alike. ****-------****-------****-------****-------****------- For Pansat 2500/FLU new conversions and converted to 2700 Use only on converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones In case you have difficulty getting the latest BIN, it is available here. Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest jvvh_235 files for Pansat or Fortec remote The latest CS_233T_lightning Bin included These three files are also available separately for those who do not want to download the full kit http://public.box.net/2500_full_kit FOR FIX dated 3rd January, 2008. |
