Can anyone help me ?
Username: Jerkisland
Post Number: 70
I loaded the new bin file and channel file for viewsat extreme, though it said everything succesfully I get no channel displayed on the receiver. I had to do a blind scan to get the channels, can someone tell what might be wrong that I didn't get the channels when I loaded the CHA file along with new bin file?
Username: Saqeeb9000
Post Number: 1344
i think ftatester is tired of this... here is what to do by ftatester..
https://www.ecoustics.com/electronics/forum/home-video/428318.html
Username: Ke5aqn
Post Number: 3198
sure just like did for you last time...
I made a guide for you! Next time do what it say's and in 5 min you will watching tv, eating popcorn enjoying life and not looking at a receiver with no channels
Post Number: 71
Sada Bhai, I tried exact same steps but even though Channel file (*cha) is succesfully downloaded, I still don't see the channel list.
Username: Ke5aqn
Post Number: 3200
you missed something.....cheak the cha file useing osdedit
Post Number: 1347
are u getting signal right...
did u check your port setting
every thing is correct?
Post Number: 72
FTA Tester, I opened the file using OSEDIT and it successfully opened and I see all my favourites but when I download it on my receiver I don't see the channels at all.
Post Number: 73
Signal is more 90%, port setting is set to COM1 and baud rate to 115200.
After doing blind scan I get all the channels.
Post Number: 1348
Post Number: 74
Yes I get all the channels and then i have to sort them again.I wanted to avoid to do the blind scan by creating the SAT file and Channel file but that didn;t work as when I loaded Channel file though it was successfull I didn;t get my channels or favourites.
Username: Ke5aqn
Post Number: 3207
just do a factory reset, and put the satfile and channel list in from the computer....easy
Post Number: 75
Did that too and same result. I guess may be the channel file and uploaded from STB to PC was not done right. Hence I will do it again using OSEDIT. Going by the rate of ECM I am sure it will come handy. Thanks for the help FTA Tester and Sada Bhai.
Username: Ke5aqn
Post Number: 3210
i dont get it
you used the loader program to install the channel list into the receiver?
Post Number: 77
Yes I used Loader 2, loaded the bin file and then loaded the channel file and hit PC -> STB. The download was successfull. When i turned on the reciever I saw that the new bin was there but I was not seeing any channels (and Favorites I created).
Username: Ke5aqn
Post Number: 3213
ok for some reason the list did not "take" oh and you forgot the satfile!
factory reset, new bin, satfile, channel list,
make popcorn, watch tv
Post Number: 79
Also when I edit the cha (Channel) file in OSEDIT I see all my favourites and the channels listed under the favourites.
Post Number: 80
Do I upload the SAT file from STB -> PC in the same way I did for the channel file ?
Username: Ke5aqn
Post Number: 3219
go get a fresh one from viewsatusa.com its on their support page
Post Number: 81
Thanks got it from viewsatusa.com. Thanks for your help.
Username: Ke5aqn
Post Number: 3228
cool no problem...
