Bronze Member Username: Sandy12421Post Number: 41 Registered: Jul-06 | i fixe new bin file but dish is working god but bev is stille say outoroling so bev is not working with new file some one pls help me |
Gold Member Username: NydasPost Number: 6833 Registered: Jun-06 | How do you expect people to repond, if they do not not the name of your receiver? |
Silver Member Username: HshakarchiPost Number: 185 Registered: May-06 | depends which one if you have VS ultra it is working for both DN & BEV but if you have VS Xtreme only DN For now, they promise that an Xtreme fix for both Dn & Bev will come soon. |
Bronze Member Username: Sandy12421Post Number: 42 Registered: Jul-06 | i have viewset extrem |
Bronze Member Username: Sandy12421Post Number: 43 Registered: Jul-06 | hanibal53 thake you very much for u give me help thake you vedry much |
Silver Member Username: HshakarchiPost Number: 186 Registered: May-06 | go to ftaforall*net, you see there that for VS all are working for both Dn & Bev except for Light/Platinum and Xterem only DN for now. |
New member Username: GregrafPost Number: 9 Registered: Dec-07 | if u use the new bin with bev it will freeze. |
Bronze Member Username: GregrafPost Number: 11 Registered: Dec-07 | with extreme |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3134 Registered: Sep-06 | Sandy, Their is nothing you can do your receiver needs a new bin in order to receive BEV. Read the text doc that was included with the bin......or the warning here |
New member Username: Max_paynePost Number: 2 Registered: Aug-06 | hi i need new bin file for pansat 2700a please. you can send to my email. tyger79_@hotmail.com thx |
Gold Member Username: NydasPost Number: 6837 Registered: Jun-06 | lee lee: Please do not highjack threads. You have already been told to go to for your BIN. |
Bronze Member Username: DafidofPost Number: 22 Registered: Dec-07 | I've download the new bin for vs ultra, and tring BEV but it autoroll, and screen is still black. there is no freeze, but can't get BEV channels. Please need your help, did that bin works for BEV, or is there something else I must do. All my settings are ok. thank you |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 3175 Registered: Sep-06 | Dafi, That bin as is STATED all over the internet in ever forum DOES NOT WORK FOR BEV. The bin DOES NOT WORK FOR BEV. here is how to get bev: Wait for a new bin THAT BIN DOES NOT WORK FOR BEV Also if you want to watch BEV read the above post's they all read that THAT BIN DOES NOT WORK FOR BEV! I hope I made that clear. |
Bronze Member Username: DafidofPost Number: 24 Registered: Dec-07 | Thank you TESTER, so that bin doesn't work for bev? looool |
Bronze Member Username: Fast107Post Number: 17 Registered: Aug-07 | hey |
New member Username: Scott21Post Number: 6 Registered: Sep-07 | hey tester it is working on bev for me on my ultra. so dafi check your atuoroll? |
Bronze Member Username: XsmokerElderbank, Nova scotia Canada Post Number: 18 Registered: Dec-07 | New bin for vsplat works only with dn. Had it in for awile and dn going good.All channels. |
New member Username: Slow990Post Number: 4 Registered: Dec-07 | thanks dana keddy |
New member Username: Scott21Post Number: 7 Registered: Sep-07 | dafi make sure you are using the 2nd version to get bev the 1st was only good for dn only !!! |
New member Username: Scott21Post Number: 8 Registered: Sep-07 | it is 080104-1u so make sure it has the -1 |
