Help with loader for 2700a !
Username: Cooljo
Post Number: 10
someone please confirm that this is the loader i need to use for my pansat2700a
Pansat 2700 GTRom Loader v3.35
Username: Jowhar
Post Number: 152
is it clone
Username: Cooljo
Post Number: 11
no, i am new at this..but i think it is an original
Username: Iamdrumming
Post Number: 61
Hi Joan,
If your 2700a already has b-75 on it, the latest loader is GTRom Loader v27.02 [Pansat2700A - B75].exe
People just call it v27.02
Username: Cooljo
Post Number: 12
sorry for this silly question , but how do i find out if my 2700a has a b-75 on it????
Post Number: 62
No silly questions here :-)
As soon as you turn on your 2700a, 'b-75' should scroll across the display a couple times. Then you know your 2700a has 'b-75' on it. B-75 is the update that took place back in March.
Username: Jowhar
Post Number: 154
turn off your receiver and on you will find out
Username: Cooljo
Post Number: 13
ok..i'll do that
Post Number: 63
Also, since you are new, I really recommend going to the official Pansat site. It is:
http://www.future-fta.info
The site is down right now, but once it is up, you'll find lots of info there. Don't go to any other website that is usually spammed here.
Username: Cooljo
Post Number: 14
hmm..nothing happened,i dont think any update has been done in a year since i have this unit.!!
the last time the bin changed,i was too skeptical to do it my self, now with most of the channels gone,i have no option!!!
Username: Dimwitt
Post Number: 346
to check boot version
either press the menu button and the system info will be in the lower right of screen --boot ver.
or
reboot receiver by turning off then on with the backswitch --the boot ver. will be displayed on the receiver -looking for b-75
Username: Cooljo
Post Number: 15
ok i will go to the website you recommended...
Username: Cooljo
Post Number: 16
ok the system info says
x-87BL
API:2.92-Eubx
BOOT VER:6.2
25 JAN 2007
Username: Cooljo
Post Number: 17
GUYS..TELL ME SOMETHING,ABOUT THE SYSTEM INFO I JUST
POSTED......
AM I TOO FAR BEHIND..
Username: Cooljo
Post Number: 18
OK..ONE MORE INFO I ALREADY HAVE A
GTROM LOADER V27.01 ON MY COMPUTER,WHICH I DOWNLOADED IN OCT WHEN THE BINS FIRST CHANGED ...CAN I USE THAT??
Username: Dimwitt
Post Number: 347
go here www.pansatusa.com/download.htm
read the instructions for 2700 b-75
everything you need to upgrade to b-75 is included in the 2700b-75 software
then download the latest bin which can be found at future-fta.info
Username: Cooljo
Post Number: 19
THANKS A LOT TOOTER, I WILL DO JUST THAT.
Username: Charjam
Post Number: 286
i have a 2700a and you need 27.02 loader but there are two of them one says write file and the other says download the one that says write file does not work for me
Username: Cooljo
Post Number: 20
try downloading it,i did the same.
