Ariza 700 autoroll option
Username: Chichos26
Post Number: 55
how i can go in autoroll option in Ariza 700
when i hit menu then parental control under old pin enter 2004 and is only for change the old pin
Username: Saqeeb9000
Post Number: 1364
i don't have ariza.. but did you check it on setting..
Username: Chichos26
Post Number: 57
is not there
Username: Aysa
Toronto, On Canada
you have to press 'i 2004' to get in
does anyone know which file is for the ariza 750 from mingo jan 2 2008 fix? i appreciate the help
Username: Ustaad_hc
Post Number: 532
bin start with AA-2
Username: Chichos26
Post Number: 64
AHHH OK THANS SAFA (( I )) = INFO KEY OK OK OK
ARIZA 750 aa-2_h20080102_309e_MINGO.bin
Username: Chichos26
Post Number: 65
AFTER LOADED THE IN SET DEFAUT KEY A AUTOROLL ON
