New member Username: Prowler9Post Number: 8 Registered: Dec-07 | Hi, I had posted my problem under https://www.ecoustics.com/electronics/forum/home-video/425455.html a different thread using different name, anyway my reciever display is still showing 5 and it stays the same.Tried everything load the CS_235 bin and/or b75_m_1 etc.The bin will burn but when the reciver reboots it stops at 5 and stays that way. Pls help, is my reciever dead? |
Gold Member Username: Saqeeb9000Post Number: 1314 Registered: Oct-07 | did you check the cable .. like did u tried before with the same cable and it worked for you.. most of the time its problem with cable.. if cable is ok... check the loader you are using.. make sure you use the latest loader... use reputable website to load the bin.. and ur reciever is not dead.. its just having communication problem... and next time use only one name.. choosing a girl name or diff name won't help you to get the answer fast... let me know if it worked out for you.. |
Gold Member Username: NydasPost Number: 6871 Registered: Jun-06 | Do a revert to 2500 using Chancy's instructions. The whole subdirectory is in the fll_kit8 http://public.box.net/2500_full_kit |
New member Username: Prowler9Post Number: 9 Registered: Dec-07 | Hi sada,this cable's been working for me in the past and even now it burns the bin(cs_235)but when I try to load the (b75_m_1)I have "write failed" and as Nalin advised in my previous thread I tried the revert to 2500 but the flas update fails using the 2700 to 2500 converter. |
Gold Member Username: Saqeeb9000Post Number: 1318 Registered: Oct-07 | so i think there might be problem with the loader or file itself make sure you unzip the file before loading.. and dont make a shortcut on your desktop .. when its unziped in some folder ..try to download it from there.. |
New member Username: Prowler9Post Number: 10 Registered: Dec-07 | Yes I did all that, unzip files to folder using the loaders from the full kit.Reboot and hit the write bin etc.I am not sure if there is a way to clear the flash memory so I can start again,pls advice. |
