Help Bin for Pansat 3000!
Username: Sarahk
Thunder Bay, Ontario Canada
Post Number: 21
Hi. Which bin am i suppose to use for pansat 3000? thanks
Username: Carpie
Post Number: 37
Check with Pansat. I am sure they will tell you what you have to do with a Pansat 3000.
Username: Dimwitt
Post Number: 340
its a pansat 2500 clone , it will need to be converted to take modified pansat 2700 files.
cs 235t is latest bin
you could join ftaview.com and find files and how to's there.
[link removed]
Username: Nydas
Post Number: 6732
Pansat 3000 is a Pansat 2500 clone.
FOR FIX dated 3rd January, 2008.
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest jvvh_235 files for Pansat or Fortec remote
The latest CS_233T_lightning Bin included
These three files are also available separately for those who do not want to download the full kit
http://public.box.net/2500_full_kit
