Exige Audio and Alteraudiousa
Username: Nd4spd18
Northwest PA
Post Number: 4997
Hey, I know you both are CDT dealers so I've got a question:
I have CDT HD-52 components, and I'm upgrading to a 250w X 2 amp. I've seen people put 200w each on these speakers, but I'm wondering how much is the limit?
Thanks..... (alteraudio you may remember me I bought the speakers from you a while ago)
Username: Exige
Post Number: 28
which tweeter and crossover are you using? normally 180-200w is the most i'd say you can safely go with for that set. just make sure to use them responsively. if you can hear something wrong, turn it down.
Username: Nd4spd18
Northwest PA
Post Number: 5000
They have the DRT-25 tweeter and SatNet 480 crossover.
I figured ~200w was pretty much the maximum since I haven't seen anyone run more than that........
Username: Exige
Post Number: 29
with that crossover i'd be a bit gentler...say 175 max. 560 can handle more power than the 480.
Username: Nd4spd18
Northwest PA
Post Number: 5006
Ok thanks. How much do you think they could take with the 560? I may have to upgrade.........
Username: Exige
Post Number: 32
200w would be about right. The 560's aren't the weak link...I've got about 230-240 going to mine right now with no issues. It's just that the HD-5 driver isn't built to handle as much as say an M6. I've got an M6 and DRT-26 with 560i's....they could probably take more than 240...I'd bet 275 based on how they're performing right now.
With the 480 though...the crossover becomes the weak link as compared to the driver being the weak link.
You would also benefit from a lower crossover point with the 560i....it gives that set a better sound.
Username: Nd4spd18
Northwest PA
Post Number: 5024
So you'd recommend the 560i crossover? I didn't realize it made the components sound better......
I haven't seen alteraudio here for a while so I may be interested in buying some 560is from you........ could you PM me with a price on those. Thanks.
Username: Exige
Post Number: 33
Yeah I'll PM you a price...gimme a minute or two and Ill get it to you.
Username: Nd4spd18
Northwest PA
Post Number: 5029
Didn't get the PM...... this forum sucks sometimes, just email me:
nd4spd18
AT
gmail.com
Username: Alteraudiousa
Concord
Post Number: 1610
you got an email
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13417
alter or exige...can u send me a price on a HD-62 set with the 560i crossover???
ChaunChaun3000@hotmail.com
Thanx
Username: Exige
Post Number: 34
all emails sent. sry about the PM, dono what happened.
Concord
Post Number: 1612
Just checking up to see what happened. email was sent over the new year break. PM me if you didn't get it.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1179
Could one of you send me an email on cost of HD53 braxials, with the DRT tweeter. Thanks, David.
bndrulez@hotmail.com
Username: Exige
Post Number: 61
email sent.
Username: Philly306
After 194dBs your car ..., North carolina
Post Number: 792
exige don't know if you got my PM.
but can you email me a price on a pair of hd-4" mids. just the mids
philip306 at gmail.com
thanks
Username: Exige
Post Number: 62
alright guys i think i've gotten back to all PM's now. sry for the delay. let me know if i missed yours.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1188
One more thing. Would the braxial be better than the seperate system? I was liking the idea for the ease of it.
Username: Exige
Post Number: 63
It depends....where were you planning on mounting the tweeter otherwise? Typically stock locations are not the best way to go. You'll have to do some experimenting with the tweeter location to decide what works best for your car's individual acoustic environment. There is no surefire way for each car.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1199
Well I was going to build a 5.25 wood template out of MDF to go over the 5x7 hole. Then I would have just put the tweeter next to the speaker in the same template.
I don't like the sound of the tweeter being to far from the speaker. Doesn't match up well for me.
Had it in my Bronco and didn't like it as much as my last vehicle were it was about 6" away from the speaker and above it.
Username: Rossx1
Nashville, AR United States
Post Number: 19
Hi, Could i have a quote on both the cl-e61 and cl-62 comp. sets. my e-mail:
rossallen07@sbcglobal.net
Thanks guys
Username: Nd4spd18
Northwest PA
Post Number: 5618
Usually having the tweeter closer to the midrange is better. Problem is, the best place for the tweeter is usually in the upper part of the door. You don't want it too low or it sounds like the audio is coming from the floor.
But if your midrange has to be in the bottom of the door, having the tweeter up higher is often better even though it's farther away.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1203
Well it's mid door. A Ford Explorer.
