Tester VS ULTRA
Username: Ragidy57
Post Number: 83
hey
my ultra will now only display any numbers such as 8888 or 7777 when the serial cable is connected then turned on. Once i dont remember what i did but i did get all ---- and 0000
I tried to download the when all else fails repair and the zmodem thing comes up and it wont load or do anything.
Thanks for reading this
Username: Hotsumaro
load the factory bin, if not try jtag.
Username: Ragidy57
Post Number: 84
it wont load any file.
Username: Ke5aqn
Post Number: 2851
It needs to be jtaged sadly or its (rip) dead now
try for me
install the factory bin 3 times with the loader program see were we are
Username: Donnie1973
Post Number: 2538
if the zmodem error comes up, double click on that file (it comes with loader 2 download at total) choose open with, then browse for loader 2 program. Open with that and try again
Post Number: 2539
or C/P that zmodem file to the system folder under windows
Username: Ragidy57
Post Number: 85
what is jtaged? if its dead its nothing i can do with it huh?
Username: Ke5aqn
Post Number: 2854
I will have to study up on it some I am sorry I do not have the time tonight I will work on it wednesday..
until then
Username: Ragidy57
Post Number: 86
for some reason i think i have a clone.
Username: Ke5aqn
Post Number: 2861
I was thinking that too bud...if so its ok at least then we can fix the thing...
Username: Hshakarchi
Post Number: 176
Origonal VS Ultra Upload
Post Number: 177
CLONE VS ULTRA CHECK THE RED CIRCLE Upload
Post Number: 178
Inside Clone VS ULTRAUpload
Post Number: 179
Inside Origonal VS ULYTRAUpload
Username: Mcrabbycabby
Wpg, Man Canada
Post Number: 25
good job hanibal thank you.
Username: Ragidy57
Post Number: 87
Thank
with out opening it up. I believe its an original. It has the little heat sink looking silver thing. It also does not have the screws in the back.
Thanks
Username: Ke5aqn
Post Number: 2872
Viewsat 2000 Ultra Setup Guide Using Serial Cable (NULL) or USB
1. First you must download and unzip (extract) the DPBSWyymmddU.pgm from the Files section. FTA Receiver Files/Viewsat/VS Ultra.
It is the only file most people need.
A. Loading your BIN using Null cable:
* Connect serial cable (NULL) to PC>STB
* Open up Loader of choice (PVR-Loader 1.1 or Loader2)
* Click on Tool>Configuration>Com port (Default is com 1)
* Click on Open File
* Click on PC>STB (Notice the progression bar in loader)
* Turn the power in the back ON
* Wait for Loader say Completed. Then on box LCD front panel screen say I.N.S.T>END>0000 or until clock count to 0.001
Username: Ke5aqn
Post Number: 2876
sorry that messed up lets try again..
Here is How-To Viewsat 2000 Ultra Setup Guide Using USB and Serial cable. Hope this Setup guide will help our members.
IT IS VERY IMPORTANT. DO NOT TURN THE POWER OFF TOO SOON
* Turn the power OFF in front and power OFF in back
* After downloading and unzipping the "BIN", unhook NULL cable from PC>STB
* Connect all the cables to your box/TV
* Turn the power ON in the front and back
* Press Menu key
* Select Installation and press OK
* Select Antenna Setup and press OK
* Select your Sat.
* Here if you have a DiSEqC switch enter the port #, Motor or Legacy SW
* No LNB Type need to select (from new, you have only two selection Standard and Universal). STB will select your LNB Automatic
* Press Exit and select Yes for saving the settings
* Your back to Antenna Setup screen
* Here you have Three choices:
o Channel Scan
o Auto Scan
o Blind Scan
* Select Auto Scan
* Press OK
* You are in the Auto Scan window and you see the Bird(Sat.) you selected and on the top of your screen are three options:
o Search option
o Network search
o Scan Start
* You don't change nothing here, go down and select Scan Start and press OK
* You do this for all the Birds (Sat.) you have
* Wait for Autoroll and watch TV
B. Loading your BIN using USB Jump Drive
* Now you can insert the Memory Stick in your PC and either transfer the extracted .pgm file from your computer or you can extract it directly to your USB drive.
* Then safely remove the USB drive from you PC and insert it in your STB. In the Main Menu select System information and press OK
* Select Receiver Upgrade and press OK
* Go down to the bottom of the window, select USB and press OK
* A new window opens with some Korean files, years, etc.
* In the bottom of the window, it is your bin selects and presses OK
* Press Menu key
* Select your Sat.
o Channel Scan
o Auto Scan
o Blind Scan
* Select Auto Scan
* Press OK
o Search option
o Network search
o Scan Start
* You don't change nothing, go down and select Scan Start and press OK
Enjoy!!!!!
Username: Ragidy57
Post Number: 88
I went to DSSTESTER site and could not find that file
Thanks
Username: Ragidy57
Post Number: 89
ok i know what that file is now i was thinking it was something new
Username: Ke5aqn
Post Number: 2879
http://www.thetotalfta.com/forums/forumdisplay.php?f=152
their is your section of total.
Username: Prar69
Post Number: 95
Tee,
go to FTABINS dot net, they have all files that you need for Ultra
or use the link below
http://www.ftabins.net/forumdisplay.php?f=114
Username: Ragidy57
Post Number: 90
That is what i did and how i set the box up. I was scanning channels and was getting doubles. I was trying to delete all the channels and i was going to set it up in another room where i could get a better signal. That is when the panel started rebooting over and over right after another. Thats when i started adding the other files and programs. I think the box is dead. the red light on the box comes on. the panel will display the numbers when ever it gets ready by turning it on and off. The loader 2 i have cant transfer any files into the reciever now.
I got it from the listing here. It says i can send it back with no questions asked and they will fix it. do you agree with that or?????? i dont want to get in trouble.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D250198322525&ru=http://el ectronics.search.ebay.com:80/250198322525_Consumer-Electronics_W0QQ_trksidZm37QQ catrefZC5QQdfspZ1QQfbdZ1QQfclZ2QQflocZ1QQfposZ24588QQfromZR14QQfrppZ50QQfsooZ1QQ fsopZ1QQfssZ0QQftrtZ1QQftrvZ1QQnojsprZyQQpfidZ0QQsaaffZafdefaultQQsabfmtsZ0QQsac atZ293QQsacqyopZgeQQsacurZ0QQsadisZ200QQsaobfmtsZexsifQQsargnZQ2d1QQsaslcZ0QQsas lopZ1QQsofocusZbsQQsorefinesearchZ1QQfviZ1
Username: Prar69
Post Number: 97
Tee,
If you don't know how to JTAG it, take it to any dealer that sells Ultra and ask them to fix it.
They should be able to do it in 10 minutes and then you will need to load the original bin followed by the new bin once it is released.
Don't send it back to any one, just go to where you got it from and ask them to fix it
Username: Ragidy57
Post Number: 91
That is where i got i from. I dont think anyone sells these boxes in VA
Username: Prar69
Post Number: 98
VA as in Virginia? You want to tell me that no one in all of Virginia sells FTA's? Man just open the Yellow pages and you will find a ton, or just google it
Username: Farmboy491
Post Number: 7
al7bar dot tk has an excellent file section too. I found the last fix there even before totalfta had it.
Username: Konikgarbusek
Post Number: 22
You cannot JTAG Viewsat receivers.
Username: Ke5aqn
Post Number: 2887
Jan ,
Please do alot more reading and studying before giving advice. Your statement could not be any more wrong.
Tee,
Please ignore her misinformed statement.
Yes I would contact the seller about an exchange now while we are waiting for the new bins you have nothing to lose...
Username: Ragidy57
Post Number: 92
Tester, I did get the factory bins loaded into the boxs before its went dead. So it should show up as factory, correct? my question is what should i say to him when i email him about it? What would diffently keep me out of trouble.
Thank
Tee
Username: Ke5aqn
Post Number: 2889
The sellers all know what we do with the receivers. I would tell him a small "white lie" that it keeps rebooting itself and will not accept any files such as a channel list and its unusable to you.
good luck
Username: Ragidy57
Post Number: 93
Thats what i was thinking. they know what the deal is... thanks for the advise.
Username: Ke5aqn
Post Number: 2916
Your a cool dude wish like heck we could have got it going....whats the 57 in your username for a car?
