Cw dish??
Username: Chilli
Post Number: 57
What type of dish do you need for the cw receiver??The regular dn dish or something different??
Username: Lomna
Post Number: 50
you can use regular dn or dt's 18 inch dish with single lnb.
Username: Chilli
Post Number: 58
cw 600s??? can you load programs with a usb or does it have to conect to your computer
Username: Diggy101
Post Number: 41
he is right. Good info!
Username: Brucester
Post Number: 934
no you can not load the cw with meery stick but if you get the pvr-100 you can usb stick to load the bin file to the cw600p through the pvr you can get a deal if you get the cw600p and the pvr-100 for i think 160 hope this helps
Username: Asharfi
Post Number: 1679
babies12,
It all depends where you wanna point your dish at. A 36' with 2 lnbs is good for Dish 100 & 119 as well as Nimiq 1 and 2
