After Install...
Username: Sportquest
Nashville, TN USA
Post Number: 16
I just had some subs and a amp installed in my car, everything powers up just fine, but i noticed tonight when i went for a drive that some of the stuff that should be lit up wasnt, i noticed a couple of things, my ac/heat control knobs, etc and
my gas hand, any thoughts??? before they were working
Username: Sinful_systems70
15 INCH WANG...
Post Number: 1084
Some wires may have touched togeather or to some metal. Try checking the fuses in the fuse pannel.
Nashville, TN USA
Post Number: 17
ok Sinful, I'll check them in the morning, Thanks.
Username: Teamrevolution
ATLANTA, GA USA
Post Number: 177
Yep i would bet he is right. if the yellow or red wires touch a ground then the fuse is gone. Does your door chime still work?
Nashville, TN USA
Post Number: 18
my door doesnt chime, the car "beeps" when the key is in the ignition, but yeah, it still works
Username: Nd4spd18
Northwest PA
Post Number: 5128
Yeah check fuses, but if they are good then whoever did the install may have f*cked something up, maybe pulled out some wires in the dash.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 1591
It sounds like they had to unplug your power to your lighting for the AC and stuff and forgot to plug it back up when they put the dash back together but I would check the fuses before I pulled the dash apart
ATLANTA, GA USA
Post Number: 179
needle nose plyers and a flash light. In some cars there are a few fuses that can pop and still allow the stereo to play. Depending on what wire grounded.
Nashville, TN USA
Post Number: 19
i checked all the fuses, not the fuses under the hood tho, but under the dash, they were all fine. Im guessing a wire behind the dash or something, i just hope it dont fu(k up my electrical system.
Rock Vegas, NC US
Post Number: 1595
did you get a shop or a friend to do it? If it was a shop and something is screwed up, thats something they have to deal with...
15 INCH WANG...
Post Number: 1088
I bet, since it worked before and not now, that the HU got hot and possibly melted wires or the wires got smashed during install. Sounds like a horrible/sloppy install to me!!! JMO
15 INCH WANG...
Post Number: 1089
I bet they used electrical tape... LL Cheap route!!!!!!!!
Nashville, TN USA
Post Number: 21
Andrew, I had a shop install everything.
Nashville, TN USA
Post Number: 22
lol Sinful, who knows these days..I was gonna take my car back to the shop and tell them to find the reason this is happening, but i dunno now lol.
15 INCH WANG...
Post Number: 1090
I wouldn't take it back to a place that fucked it up the first time...You always need good quality service so find a trust worthy/honest amd skilled installer to help you out in the future, or spend some time and learn how to DIY.... JMO
Nashville, TN USA
Post Number: 23
Sinful, I would but I dont know anybody that I trust, I always heard to stay away from Best Buy, Circuit City, etc. I guess I'll just research on how to take apart my dash and look at the wiring myself.
Username: B3n07
Louisville, Ky USA
Post Number: 639
lee jst take it back to the shop get your money back why let them f your car up and walk away get your moneys worth either have them fix it or ask for them to refund your money for faulty instal cuz i bet you have a contract with this shop right???????
