New member Username: SammyusPost Number: 5 Registered: Dec-07 | I have a Sub-woofer with the following ratings: - Impedance 8ohms - Input Power (IEC): 250W (MAX) Most of the sub-woofer amplifiers I searched gives me power rating at 2 or 4 ohms. Can anyone please help me in identifying the right amplifier for my sub-woofer? What power I should be looking for? Thanks |
Silver Member Username: HuronPost Number: 337 Registered: Mar-07 | im not an expert on the, subject,,,get it haahaa,,but anyways post this in the speaker section or amp section to make sure, but your sub would give a lesser load to the 2 or 4 ohm amp unless somebody thinks otherwise you shouldnt have a problem, I know a 2ohm diffrence would not matter, if it was the other away around then there would be load issues on the amp, if your speaker can handle 250W max then find an amp that will go say 300W at least |
Platinum Member Username: Project6Post Number: 14178 Registered: Dec-03 | Sameer, go here http://www.partsexpress.com/webpage.cfm?webpage_id=3&CAT_ID=43&ObjectGroup_ID=75 6 |
Gold Member Username: John_sColumbus, Ohio US Post Number: 2019 Registered: Feb-04 | "Sameer, go here" Which is what I told him..... https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=3&post=1378338#POST1378338 BTW, good to have you back Berny! |
Platinum Member Username: Project6Post Number: 14180 Registered: Dec-03 | Thanks John S Sameer, Just get a Dayton power amp and you should be good to go. The 2 or 4 ohm load in the specs mean those are the type of loads it can handle. It should be able to handle your 8 Ohm subwoofer. |
