Fuse help
Username: Splmonster
C-Town, OH USA
Post Number: 1444
i got my hd3 running off my ed nine.1 and my fuse keeps blowing, wat size fuse should i get? or is there another reason its blowing
Username: •cam•
BC Canada
Post Number: 1431
Does it blow when it goes on, or when you really start cranking it up?
What are the blowing fuses rated for?
Username: Somedonniedude
Illinois United States
Post Number: 625
Is it your inline fuse? (basing it on the fact he said Fuse, and the amp has 3 fuses i think?)
If its the fuse under the hood, then prolly too small of power wire. What guage do you have and how many feet?
Username: •cam•
BC Canada
Post Number: 1434
Explain why too light of a power wire would cause a fuse to blow, please.
Username: •cam•
BC Canada
Post Number: 1436
Bump. I'm very interested to learn here, Donnie. Don't let me down.
Post Number: 631
If you have too small of a wire, wont that be less efficient, and cause you to pull more current throughout the wire than needed? Therefore overloading the fuse and blowing it if thats the case.
He also might have too small of a fuse under the hood, not disagreeing with you, i'm just stating another possible issue.
Username: •cam•
BC Canada
Post Number: 1443
Nah, it won't draw more current. It can only carry less. He very well may have too small of a fuse lol. We need an answer to help, however. Where is this dude?
Post Number: 633
Can amperage be lost in heat, or a hot wire? I found this calculator once and was playing with it, and I noticed everytime I added more feet of wire on, or dropped the ga of wiring, the amperage pull was increased.
Post Number: 634
Maybe im confusing amperage and voltage.
Username: •cam•
BC Canada
Post Number: 1444
Voltage is the energy possessed by electrons, amperage is the speed the electrons travel. Hmm. Got a link to the calculator?
Post Number: 636
I've been trying to find it, but no luck. I thought it was on bcae1.com
Username: •cam•
BC Canada
Post Number: 1448
I thought I might have seen one there, as well. Thanks anyway.
Username: Nd4spd18
Northwest PA
Post Number: 5049
Which fuse is in question here?
What size power/gorund wire to you have?
C-Town, OH USA
Post Number: 1445
srry i was at work haha well i have 4 gauge wire and the fuse was 80. and yea its my inline fuse
C-Town, OH USA
Post Number: 1446
and its wierd becasue it'll play for a while i can crank it up and then like a week later it'll juss blow on reg volume
Username: Safe_cracker
Chicago, IL US
Post Number: 3823
Oh ya, which way does electrons flow, pos to neg or neg to pos? :-O Polo..
Post Number: 637
How many feet power/ground?
Username: Nd4spd18
Northwest PA
Post Number: 5070
Ya need a bigger fuse...... 4 gauge wire can have a max fuse size of 125 amps. Get a fuse as close to that as possible but not larger.
Username: •cam•
BC Canada
Post Number: 1449
Negative to positive!
Next question.
Username: •cam•
BC Canada
Post Number: 1453
Yeah, those NINe.1s have a max current draw of 130A.
