Opinions on this amp
Username: Dakangofkrunk16
Post Number: 1000
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?Source=googlebase&Pro ductID=18160
Thats is one hell of a cheap amp from what it is marked down from... Worth gettin it, is it any good
Username: Eldog
Pittsburgh, Pennsylvania
Post Number: 28
Ask Andrizzle, I believe he bought a brand new one fall/late 2007. A Maxxsonics company although the Mean Machine line is a little better than their Super Sport line.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5137
i'd only buy MEAN MACHINE line, other models look cheap.
I think you'll be better buying Crunch ground pounder line if you wanna keep maxxsonics stuff
Username: Nd4spd18
Northwest PA
Post Number: 5817
Autotek > crunch
Autotek is one of maxxsonics decent brands, I believe they do rated power. Crunch is one of their cheap brands...........
