Gold Member Username: Saqeeb9000
Post Number: 1227 Registered: Oct-07
Posted on just wondering any one has same problem.. my internet is fine.........and it can detect internet and can do upgrade but no channel is working... |
Post Number: 1228 Registered: Oct-07
Posted on upagain...may be an ecm change.............. |
Silver Member Username: Vndpatel
Post Number: 425 Registered: Mar-06
Posted on no mine has been working fine. try rebooting it |
Post Number: 1229 Registered: Oct-07
Posted on yes its working with rebooting ... is your pvr working good... i am having problems with mine... |
Silver Member Username: Yakovaki
Post Number: 155 Registered: Sep-07
Posted on sada did you try the router settings and did you try the version 0.75? how fast is your computer? i dont remember what the min requirements are for pvr |
