Frustrated In Charleston, SC Unregistered guest | Just had Direct TV installed, installer said to call Direct TV to purchase HD antenna for local station reception and was easy to hook up. They had no idea what I was talking about so went to Radio Shack and bought Terk 44. Directions don't match up with my multi-switch. Antenna has 4 in's and 4 out's, multi-switch only has 1 antenna in. Was told this antenna would work but now I don't think so. Am even under the impression the Terk's don't work well. Any suggestions/help would be outstanding. |
Mr. Whitefolks Unregistered guest | Hey Gamecock, best advice i can give is don't listen to anyone at R@dio Shack. Also you leave a trail there on what you buy so keep it legal dude or else you may end up a$$ up in the peneTaintury as the "brothers" say. |
Mr. Whitefolks Unregistered guest | Hey Gamecock, maybe we could cyberchat for a while...get to know each other? Email me at chunklover53@aol.com |
Anonymous | Anyone else????????????? |
