Soundstrem eqipment???? helppp
Username: Mike_16
Reedsburg, Wisconsin Us
Post Number: 796
ook my friend just got 2 12 inch t4 tartantula subs and has the tr/1600 tarantula amp. ok we got it all hooked up and it f..ckin slams. but is that amp reliable?
Username: Talon01
12 audioque 2.5 145.2 ..., Pa Usa
Post Number: 570
soundstream is a good brand , i would say yes in my experience
IM THE REAL SLIM SHADY
Post Number: 16370
soundstream is a reliable brand. alot of the competitors use it.
Username: Shak180
Hayward, California Usa
Post Number: 130
so if soundstream is good then power acoustiks(sp) is good too then right ?
Username: Rovin
4 10 Pioneer...
Post Number: 12650
good in this case means it works but nothing to brag about....
Username: Nd4spd18
Northwest PA
Post Number: 5016
power acoustik is not good. Hence why people call them "power crapcoustic"
Soundstream USED to be good. Their older amps are good quality. Most of their newer stuff is budget category.
Username: Gignmofo
That particular amp is very good. newer stuff not so much.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1141
as much as their amps cost they shouldnt be that bad,and yeah alot of competitiors use them
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 962
My old setup had a newer SS 4 channel and it was crap. Clipped like a mofo with the gain at 1/4
I have an old SS REF series amp now and it's great, beats the crap out of my Type R.
Username: Mike_16
Post Number: 797
yea he has slot box with the 4 subs. nd that amp i listed. its rted liek 1600 at 4 ohms ad 800 at 2 ohms. but if the subs are only getting 400 apeice why do they soud a lil distorted when they hit some highs? the lows sound bad a.ss. and we just have it on his back seats ts rite behind us when we bumping it. but idk that amp is so bg and cost o muh or only being 1600 watts an 2 ohm. buthe got all the am subs box wiring from my frin fot 600. i thought it was a good pice. he was gunna get the mtx 81001 amp. i doubt those subs can hanl 1800 and 900 rms . both r getting about 400 and soubd a lil distorted wen the highs cme in. i think tha amp may be underrated. is it???
Username: Mike_16
Post Number: 798
bump!!
Username: Mike_16
Post Number: 799
bump!!!
Username: Nickyp0219
Post Number: 266
Sorry man, I can't help you, but I got to point out, your grammar in that paragraph is some of the worst I've seen. =P .....think of this as a free bump too
