Which components for this setup?
Username: Rossx1
Nashville, AR United States
Post Number: 14
please help me pick a set of components and an amp.
my setup is as follows:
Alpine 9887 h/u with imprint
us amps md3d amp
image dynamics idmax 10
factory 6.5's all the way around.
i am way over budget on the rest of my setup so i would like to keep the cost on my front componenents and amp below 350.00.
btw i like my highs loud.
Thanks in advance
Ross
Username: Adddisorder
Palm Beach, Florida
Post Number: 5701
your budget is pretty low seeing as you have some quality stuff, components arnt really a place where you want go cheap as they are a big part of the system, anyway i would suggest some rainbow slc 265s you can get them around 225 premier-audio.com will give you a good price
Palm Beach, Florida
Post Number: 5703
oh and throw them right around 150rms each and they will be happy.
Username: Rossx1
Post Number: 17
suggestions for cheap amp?
how about this one? enough power?
Zapco I-2100 - Zapco iForce Series 2 Ch. 350 Watt Amplifier
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=592
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1063
Kicker 350.4 would be much cheaper and shell out more power.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 1064
That Kicker would put out 175x2, instead of the 100X2 of the Zapco. Then you could keep the gain down and not worry.
Palm Beach, Florida
Post Number: 5712
directed a802 is pretty cheap and does 150x2
