Okay so I have a 4gauge wire running to my trunk then splitting to 2 8gauge wires one for my Alpine MRV-F345 amp and the other to my Alpine MRP-M450. I used the calculated way to set my gains using a voltmeter but after playing awhile my MRV-F345 amp that runs all my regular speakers if i turn it up alot will cut out and leave only the bass playin and when I check the amp its flashing "CUR" for over current
Would this happen just because of gain issue because on F345 amp gains are digital and not a dial so I cant get exactly the Volts I calculated or could there be somethin wrong with the amp or wiring?
