Pansat or other
Username: Sharpes84
Post Number: 59
Hello
I was a fta user for years but got away from the hobby but want to get back in.
I had a Pansat previously.Which box should I go with?
I plan on using small dish...so I am open to suggestions ...where would you recommed to buy?
A few sites have closed hat I purchased from before.Thank You
Username: Satgrl
Post Number: 1286
the good receivers now with file supports are viewsats and soniviews...try to purchase from ebay..its cheap!
Username: Ke5aqn
Post Number: 2755
I am a huge fan of the Viewsat platiumn it can be won on ebay "buy it now" for $130 shipped now.
The viewsat works about the same as a pansat with one BIG HUGE IMPORTANT feature not found in pansat's.
The Viewsat can ID The sat its antenna is pointed at making installing easer and everday use more enjoyable.
I always suggest users to try to get receiver, 31" dish, motor, and the QPH-031 lnb like I have here. That way you can receive all sat's. In times like now with most of DN and all of BEV not working I still have 100's and 100's of channels to watch.
For a complete system it is around $300 ebay prices if you get the plat light a great starter receiver.
Username: Mufta
Post Number: 298
ViewSat Ultra...
Username: Ke5aqn
Post Number: 2770
Guess with all the trouble users are having with updating that receiver I am getting scared of it now
just my observation..
Username: Mufta
Post Number: 300
i've pansat 3500sd but always have problem with epg and clock, but my friends have VS ultra and they seem happy with it. i could be wrong.
i'm planning to buy a second one but confused to go for vs or sv......
Username: Ke5aqn
Post Number: 2773
I have a 3500 as well yes the clock and epg are not great....we just look at tv guide all the time LoL
VS plat light is a easy box to use and update its $130 shipped
Username: Donnie1973
Post Number: 2509
sv4000
best support
easy to load
150 shipped
why go backwards with a vs platnum?? come on fta... they dont even have componant out
Username: Mufta
Post Number: 302
so what is the big difference in vs ultra, plat and extreme? any big dif. or jsut to confuse us...
i used to have 2700 and was very happy with that, but i sold it and bought 3500sd for the sake of updatin bins using sd card.
Post Number: 2511
usb drive
7 day epg
the plat and extreme are the same except the extreme has componant out
Username: Mufta
Post Number: 305
thanks!
i think component is better than the regular audio/video cable...
Post Number: 2513
yw, yeah.. its better.
