HOW U KNOW WHAT ROM THE CARD? AND WHAT REV
Username: Cartier1
Post Number: 1594
I GOT 2 YELLOW CARD . HOW TO KNOW IF IT'S ROM 102 AND WHAT REV????
Username: Donnie1973
Post Number: 2462
on the back, it wil say
Username: Jurj1
Post Number: 301
Cartier, Don't even go there, that sh1t is too complicated for a someone with a small di*ck and brain like you
Username: Edlittle
Post Number: 25
Username: Creek
Smithtown, New York
Post Number: 421
LOL...LOL
Username: Cartier1
Post Number: 1596
LISTEN TONY . I USED TO DO THIS LONG TIME BEFORE YOUR MOM SUCKED MY D*ICK. IT HAS BEEN A WHILE I DONT DO PLASTIC . EVERYTHING IS FORGOTTEN . BUT THE THING I WILL NEVER FORGET IS WHEN I STICKED IT IN YOUR MOM a*ss and s*hit went out from her a*ss and she said i wish tony was here to see me getting f &ucked
dantetn no it does not say.
Username: Jurj1
Post Number: 302
I hope you speak better than you post, but then again, I shouldn't be making fun of your handicap you F*UCKING RETARD!!!!
Post Number: 2463
what are the numbers on it?
1020001P07 AA-07 115434 S00 5XXX XXXX XX ROM102
1020001P07 AA-07 115434 S00 6XXX XXXX XX ROM102
like those?
Username: Cartier1
Post Number: 1598
no dantetn says dish500 and it;s yellOW CARD.
the back has S 00 4280 XXXX XX ALOS ON THE CORNER 132037 NAGRA ID SW04 THE OTHER ONE START WITH 3244 XXXX XX 127843 NAGRA ID SW02
I THINK USING THE ISO WILL SAY .
Post Number: 2469
it will, plug it into a reciever, but not one connected to a dish
Username: Ndn3
Post Number: 51
easiest way is to insert this card in receiver, power on and get the sys info. if you've any dishnetwork rcvr.
Post Number: 2478
just as long as it isnt connected to a dish. It could get the latest rev. No good
Username: Nbn13i_n
Post Number: 17
cartier1 , put in your box and hook the phone line up..
Username: Cartier1
Post Number: 1599
I THINK YOU NEVER HAVE A DISH NETWORK . WHEN U INSERT A CARD AND U GO TO SYS INFORMATION IT DOES NOT TELL YOU THE ROM . I HAVE A LEGIT DISH NETWORK . NALIN BIN NADIA CAN I HAVE YOUR FONE LINE TO USE FOR SECOND ?
I DONT HAVE THE ISO PROGRAMMER IS THE ONLY WAY TO SEE IF IT'S ROM 102 OR OTHERS . THANX GUYS
FU*CK YOU NALIN BIN NADIA
Username: Nbn13i_n
Post Number: 19
cartier apolgize right now and your are a free man
