Username: Johnfiac A-ToWn,
Bangn aint easy
....when u g...
Post Number: 4005 Registered: Mar-06
Friday, December 28, 2007 - 22:43 GMT friend just bought a new zx1500 and it is rated 1583.... arent they ussualy higher?
Bangn aint easy
....when u g...
Post Number: 4006 Registered: Mar-06
Friday, December 28, 2007 - 22:44 GMT 4cu 40hz and 1583 good for a 9515f daily or should i go different size?
Username: 420alldaylong Post Number: 3050 Registered: Sep-06
Friday, December 28, 2007 - 23:29 GMT Dude save your money and go with a AudioQue HDC3 15" $270 shipped. The amp you have will fit the AQ HDC3 better watts wise.
Username: Northomaha Post Number: 651 Registered: Mar-06
Friday, December 28, 2007 - 23:30 GMT yea the zx750.1s are usually in the upper 800s or 900s. but either way its underated and a high quality amp so you can't complain.
Username: Hurricanebr1an Western Burbs of Chicago,
IL
Usa
Post Number: 307 Registered: Sep-07
Friday, December 28, 2007 - 23:53 GMT that does seem a bit low
Username: Basssquared Kansas
Post Number: 1781 Registered: Nov-06
Saturday, December 29, 2007 - 00:40 GMT well they are rated at 1500 watts not 1500 plus so you should be happy ;)
Username: Nd4spd18 Northwest PA
Post Number: 5035 Registered: Jul-06
Saturday, December 29, 2007 - 04:19 GMT Kicker amps are always underrated, not always by a lot
Username: Jkidder Gunshine ,
State
Flawda
Post Number: 2965 Registered: Nov-05
Saturday, December 29, 2007 - 08:08 GMT u got jipped...
Alabama
U.S.
Post Number: 13428 Registered: Jul-05
Saturday, December 29, 2007 - 08:15 GMT lol..trade it for the same amp..and see... but u paid for 1500rms..so anything more is a good deal
State
Flawda
Post Number: 2966 Registered: Nov-05
Saturday, December 29, 2007 - 08:30 GMT right and that extra 50 to 150 watts more is not going to make any difference to your ear...
Username: Kyle_lowe Post Number: 743 Registered: Apr-06
Saturday, December 29, 2007 - 09:06 GMT i think the rockford tb's are the ones that are usually way over rated but that kicker is a nice amp
Username: Rideredder Cornell,
IL
Post Number: 1259 Registered: Sep-05
Saturday, December 29, 2007 - 09:50 GMT ^You think RF is overrated? The t10001bd puts out more than 1300wrms.
Username: Th3pwn3r Post Number:...
Post Number: 6396 Registered: Jul-06
Saturday, December 29, 2007 - 23:30 GMT He more than likely meant to say way UNDER rated.
Username: Skibum12189 Cleveland
Post Number: 2276 Registered: Mar-06
Sunday, December 30, 2007 - 00:01 GMT "friend just bought a new zx1500 and it is rated 1583.... arent they ussualy higher?" yes, mine was at like 1678 haha but ya can't say ya got jipped bc kicker says it's rated at 1500, can't get mad at em for only doing a little more than they had to.
Username: Cblaze Rock island,
Tenesssee
Us
Post Number: 1164 Registered: Sep-07
Sunday, December 30, 2007 - 01:00 GMT ya they rate it for 1500 for a reason,that might be all u get,sometimes more,and them 9515's like more power than that,that amp would be better for a 3515
Username: Basebalz13 Moneta,
Va
Usa
Post Number: 187 Registered: Aug-07
Sunday, December 30, 2007 - 05:16 GMT yea my zx1000.1's was only rated for 1036 and 1048 but i aint complaining they some niice amp but you can also run those under 2 ohms
Bangn aint easy
....when u g...
Post Number: 4007 Registered: Mar-06
Sunday, December 30, 2007 - 18:04 GMT wasnt complzainin just thought they put a bit more out, he already has the 9515 so aq is not in the question nerxt the jvc arsenal 880 ;)
Tenesssee
Us
Post Number: 1167 Registered: Sep-07
Sunday, December 30, 2007 - 19:10 GMT it wont hurt to undpower it.it would just sound a lot better if u had more power to it
