Is neosat down ?
Username: Chessy
Post Number: 45
just wondering if it is down ...
Username: Satgrl
Post Number: 1254
no its working on DN and b3v
Username: Silver1123
Mexico, DF Mexico
Post Number: 400
Do you have a Neosat?
According to TVKeyz, Neosat and Nfusion are the only ones still up.
I am planning on buying a Neosat. I have a Cosat 5000.
Username: Satgrl
Post Number: 1257
no but i know someone that owns it and they say its still running
Username: Cntrlaltdel
Post Number: 176
My Neosat has some PPV and premiums running on IKS... not all though, and whatever regular channels every other system is still getting. Nothing on BEV is up!
Mexico, DF Mexico
Post Number: 401
Hi Satgirl. According to TVkeyz.com, DN is up both for Nfusion and Neosat.
For Bev only Nfusion.
Mexico, DF Mexico
Post Number: 402
Bill, would you recomend neosat? Before did you use another FTA? I have a CS 5000 and was wondering on changing to Nfusion or Neosat.
Also, is it true that you never need to install a new bin? That all is updated throgh Internet?
Thanks
Username: Satgrl
Post Number: 1260
id stay away from tvkeyz if i was u
Mexico, DF Mexico
Post Number: 403
Thanks for the advice Satgrl
Username: Chessy
Post Number: 46
i would by nfusion .. all is up with that .. all ppv and po rn including dishnet all up there
Post Number: 177
I would actually, it's simple to load bins on to it and once they get the IKS finished, I'm predicting it'll be one of the lone FTA survivors... and I've owned CS 5000 & VS Ultra and the Neosat guide and picture quality blows those outta the water... not to mention the guide has actual channel logos like Directv has.
