Alternator Help
Username: Tsx
Hi guys, i'm planning on hooking up my system (roughly 1300watts rms) and i'm pretty sure that it'll draw more power than my car's stock alternator (105amp) can deliver... the problem is i'm not sure how much more power is sufficient for my system. i've searched all over the web for a custom TSX alternator but no luck, all they have is alternator for domestic cars only. Please help me out.
Username: Jamtochristian
Penn State , Pennsylvania USA of course!
Post Number: 21
What kind of car do you have? Stinger dealers can usually get almost all kinds of different alternators and batteries. The problem with stinger dealers is they can be really expensive. But keep in mind that you may want to upgrade your battery on that too, that is if you have just a regular old sears or walmart brand battery. Consider maybe a Optima Yellow top battery, the stinger batteries are again, extremely expensive
Username: Tsx
i have an 04 acura tsx with stock battery.
system specs:
xtant x604 with a requirement of 120amp fuse alone so i'm a little comfuse with the total power on this sytem of mine
Username: Tsx
Glasswolf! what's your oppinion?
