Kicker vs. rockford fosgate
Username: Foxbiker529aolcom
i am trying to decide between a kicker sub and a rockford fosgate sub.
the kicker is a 10" kicker comp.
the rockford fosgate is a p1s410 (10")
the subs are only about 10$ difference in price.
and they are both rated for the same power.
which one should i choose????
Username: Vtouch06
Q-TowN, PA
Post Number: 283
neither...there's better subs out there then those, whats your budget? and what amp r u running? you lookin for SQ r SPL im pretty sure we can help you out if you tell us that info. :-)
Username: Nd4spd18
Northwest PA
Post Number: 4948
Out of those I'd take the kicker
i cant really afford anything else right now.
i dont really need the best sub out there.
the reason im lookin at these two subs, is because i only have a 400 watt amp, so i cant go with subs that will handle alot of power.
i also have to stay with 10 inch for now because, that is the size box i have
Username: Zacdavis
Beloit, Wi
Post Number: 781
I'm with MS, the Kicker ;)
Username: Basssquared
Kansas
Post Number: 1756
sadly i've had both :-( and i found the P1 to produce alot clearer bass while the kicker got louder but didn't sound as clean.
IM THE REAL SLIM SHADY
Post Number: 16347
really? the p1 sounded like a one note wonder sub to me.
Username: Nd4spd18
Northwest PA
Post Number: 4971
^^^^^ The above two posts prove just how much the BOX matters compared to the sub.
Post Number: 16349
the p1 i heard was in a sealed box.
btw MS i found a perfect use for the amp you gave me. my friend is going to give me his power inverter or whatever you call that. i have a set of coaxial speakers and an old pioneer hu laying around. ima make a little box and run the speakers off the amp you gave me. lol.
Username: Nd4spd18
Northwest PA
Post Number: 4974
You mean for home audio, using a DC power supply? If you do that, make sure to use a sealed battery along with the power supply. Doesn't have to be a big one, with that amp a kentik HC600 or similar would be fine.
Post Number: 16351
oh you need a battery as well? thanks for telling me.
its going to sound good for home audio.
Username: Nd4spd18
Northwest PA
Post Number: 4975
Haha I'm glad you found a good use for the amp :-)
How many amps is the power supply you're getting? Also it needs to be 14v but I think you knew that.......
This electrical system that you're building works the same way as the one in your car, its just smaller. The battery is used to filter the current, and keep things going during peaks if the supply can't produce enough power. Ya know how its bad to run you car just off the alt with no battery in it, the same applys here.
Username: 30hrtz
Raleigh, Nc U.s.a
Post Number: 155
ya but c.c and crutchfield got buy 1 get 1 free on the kicker comps.They are decent on a low budget low power system.2 12s for 99 or 2 10s for 89.hard to beat that.Just port the comps and youll be o.k.If you get hooked on bass like I did youll upgrade quickly.Comps are ok,it just takes alot of them to get loud.Im thinkin of runnin 4 c15s on my p1000.20 cuft tuned to 38hz.5 per sub.
Username: 420alldaylong
Post Number: 3044
earle widrick
Whats budget for a 10" sub.
What amp do you have?
What ohm does the sub need to be?
Post Number: 8
the budget for a 10" is around 100$.
i have a 400 watt, planet audio??, amp (2 channel)
idk what the ohm has to be
Post Number: 3045
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17539
Post Number: 9
joey de salvo
is that a good sub??
i havnt heard of that company before,
it looks good, and it can handle 500 watts.
price isnt bad either.
Username: Somedonniedude
Illinois United States
Post Number: 609
My sis has 2 12" P1's (sealed) in her trans am and they sound descent (in a good way) and get kinda loud too, but then again its a hatchback.
Post Number: 10
yeah...
i've heard 2 p1 12's in a sealed box.
i thought they sounded pretty good.
whatever subs i get they are going in my extended cab truck.
so any sub should sound pretty loud
Post Number: 3053
earle widrick
What model is the Planet Audio amp you have?
How many subs do you want?
