Amp for Infinity Kappa Perfect 10.D
Hey, I'm looking for an amp to power the kappa perfect 10.d. I don't have it yet, but from recomendation thats the one I will get. Here are the specs:
General
MSRP U.S. $ 329.95
Power Handling, Peak 1400W
Power Handling, RMS 350W
Sensitivity 94dB (In Car)
Frequency Response (± 1.5dB) 18Hz - 150 Hz
Frequency Response (±3dB) 18Hz - 150Hz
Impedance 2 or 8 Ohms
Mounting Depth 6"
I worka at circuit city, and we have special pages for polk and infinity car stuff with deep discounts... so I'll post a few amps that we get a good deal on right here, from lowest price for me to highest.
Infinity
REF7520A
260 Watt 2-channel power amplifier
Infinity
REF7540A
520 Watt 4-channel amplifier
Infinity
REF310A
300 Watt Subwoofer Amplifier
Infinity
REF610A
600 Watt Class D Subwoofer Amplifier
Out of those, I am thinking either the REF7520A or REF310A. Here are the specs on both of those:
REF7520A
CEA Rated Yes
Power Output 97 watts RMS x 2 channel at 4 ohms and ? 1% THD + N 142 watts RMS x 2 channel at 2 ohms, 14.4V supply and ? 1% THD + N
Signal-to-Noise Ratio 83 dBA (reference 1 Watt into 4 ohms)
Dynamic Power 190 watts at 2 ohms
Effective Damping Factor 6.389 at 4 ohms
Frequency Response (-3dB) 10Hz to 69kHz (-3dB)
Maximum Input Signal 5.5V
Maximum Sensitivity 240mV
Output Regulation .078 dB at 4 ohms
MSRP U.S. $ $229.95
REF310A
CEA Rated Yes
Power Output 116 watts RMS x 1 channel at 4 ohms and ? 1% THD + N
Signal-to-Noise Ratio 81 dBA (reference 1 watt into 4 ohms)
Dynamic Power 347 watts at 2 ohms
Effective Damping Factor 6.398 at 4 ohms
Frequency Response (-3dB) 17Hz to 302Hz (-3dB)
Maximum Input Signal 6V
Maximum Sensitivity 250 mV
Output Regulation .05 dB at 4 ohms
MSRP U.S. $ $374.95
Alright, I might as well tell you that I get the REF7520A for 84 dollars and the REF310A for 127, between the two and anything else that might be better, and considering that I want to pay as little as possible. Which would be the best for just one sub. (the kappa 10.d)
Thanks for help!
