Sat/tv button on converted 2500 to 2700
Username: Goldie767
Hi all,
I have a 2500 that I converted today to a 2700, the sat/tv button on my remote used to be able to toggle between my regular tv and sattelite. Since I did the conversion this button doesn't work. Anybody have any ideas as to what I can do to get this button to work?
Thanks
Username: Ke5aqn
Post Number: 2600
I dont have one of those so just a suggestion
if the remote has buttons for stb,tv,dvd,vcr, like a viewsat or pansat along the top make sure you press stb so the remote is in "control stb mode" in order for that button you are having trouble with to work properly..
Username: Goldie767
Thanks for the attempt, but that is not it. It is a 2500 remote on the top is a button labeled sat/tv. For some reason since I did the conversion this button does not work.
Username: Ke5aqn
Post Number: 2609
I do know that sometims with the converted receivers if you put in the wrong bin the remote will not work properly.
You will probl have to live with it for a few day's and wait for the new bin....
