Nfusion Set up help needed
Username: Pratikgr
Hi All,
Just got nfusion and trying to set 110, 119 and 61.5. I have one quad Dish Pro lnb dish 500 which is pointing to 110 and 119. I also have another dual Dish Pro lnb dish 500 pointing to 61.5.
All this are connected to disque switch as follows.
Sat 1 -> 61.5
Sat 2 -> 110
Sat 3 -> 119.
I can not lock any of this birds. All this works fine with my cs400 though.
Please help me and tell me what should I put in the settings. Like, LNB Type, Diseqc Mode and Multi-Dish switch. Please help.
Username: Saqeeb9000
Post Number: 1076
ok p 40.. first of all ... before setting up any thing.. u need to download a bin mannually..
(means loader etc and using cables )... then u will get an option for sat ,setting etc..
i had same problem.. first download new bin mannually.. then after that u can use ur remote...
Username: Pratikgr
it's all done with 1.42. now I just need to lock the birds
Username: Vndpatel
Post Number: 389
official nfusion forum at [link removed]
Username: Vndpatel
Post Number: 390
BEV AND DN ARE UP ON THE NFUSION!!!!
Username: Chessy
Post Number: 42
bob john nfusion forum is not the offical site .. i think f2atv is .... there is were things are first released ???
Username: Vndpatel
Post Number: 391
ya on nfusionforum,comm they have how to guides, and they relsease new bins from there, check it out its free.
Username: Ke5aqn
Post Number: 2576
I think its not the receiver giving you trouble..
if its a dishpro lnb for 110-119 you can not use the disqc switch with it. you have to use the dp34 switch its made to add anther lnb to the dishpro lnb
drawing is how to set it up with just one receiver in your case
this
Username: Ke5aqn
Post Number: 2577
now i see you have 2 dish pro's i have the drawing for that too hang on a min
Username: Ke5aqn
Post Number: 2578
here is what I found its more complex and will require a powered switch to be able to control the 2 dishpro lnb's....i woul go find a single lnb instead
Username: Pratikgr
Can you please tell me why I need dp34? I had cs400 with twing and quode lnbs connected to disqc switch and was getting everything
Why not with Nfusion?
If so can you please provide me nfusion set up twin and quode setup ? I mean at the receiver side. Please ...
Username: Ke5aqn
Post Number: 2581
i know nothing about the nfusion sorry...
if you have the dishpro lnb's you were getting lucky getting them to work with a disqc switch. That lnb dishpro has a disqc switch built in and your receiver can only control one switch. you need to identify the lnd's better i guess. This dishpro lnb is a confusing lnb .
go look at the lnb's please do they look like the ones in the pic?
Username: Pratikgr
can this work with dp21 switch?
Username: Pratikgr
I have twin and quode
Username: Ke5aqn
Post Number: 2583
so they are not dishpro ?
it would be better to get 3 singles or BEST to get a 31"dish and the QPH-031 lnb and a motor. Then you could get all the sat's I get 2400 channels with mine
Username: Adave
Post Number: 89
go to f2atv.com official site for nfusion.
