Bronze Member Username: LoverboyzPost Number: 28 Registered: Aug-06 | Hi, I am looking for satellite signal meter to find satellite quality for me. I am trying to pick nimiq 2 and 1.3, been trying for 2 days can't get nothing. I am currently pointed to 110 & 119. I moved my dish southeast little bit nothing happen. I am in san antonio tx, lat is 29.42 and long is 98.42. According to online satellite finder I should point to azimuth 148-150 deg. 51 elevation and skew -26. I don't know what to do with skew. Thanks. |
Gold Member Username: SatgrlPost Number: 1211 Registered: Oct-07 | u can get a signal meter from ebay |
Silver Member Username: One_eye_jackPost Number: 147 Registered: Nov-07 | john You need a Birdog, very easy to use and will find the Birds every time. ![]() |
Silver Member Username: TalePost Number: 102 Registered: Sep-07 | You have to calculate elevation first and change it ! Here ! |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2560 Registered: Sep-06 | the meters are eather a cheap one that just screams when it get ANY siglal no quality or one for 500 or so that id's the sat with a quality meter as well........i ALAYS ALWAYS fix it up so i have a tv in view of the antenna while pointing so i can use the the receivers meters so do that |
Bronze Member Username: LoverboyzPost Number: 30 Registered: Aug-06 | I used dishPointer, its giving telling skew = -13.2 deg. I don't see -13.2 deg on my dish. Can somebody calculate it for me according to my dish. I have dish 500, dual lnb. Using pansat 3500. |
Silver Member Username: KirankumarNC Post Number: 399 Registered: Oct-07 | the gadget taht Yukon put up is the bet in the market,but who knows how much it costs? |
Bronze Member Username: LoverboyzPost Number: 31 Registered: Aug-06 | I saw the price about birddog on one website its more than $200. Can anybody suggest a cheaper one. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2563 Registered: Sep-06 | its just a little below the tilt for 110. so just move the dish down.....what i do is make dish lose so i can move east-west..then change the tilt just a little.....move east-west if i did not get a sig...change tilt again just a little....start with the dish tilted up moveing down a little bit each time....east-west....over and over you will get it |
Silver Member Username: JowharPost Number: 144 Registered: Jun-06 | Go here http://www.globalwholesalers.biz/satfinders.htm |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2564 Registered: Sep-06 | bird dog meter on efay now for around $350 |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2565 Registered: Sep-06 | Good find their lucky I like this one ![]() |
Silver Member Username: One_eye_jackPost Number: 151 Registered: Nov-07 | ![]() ![]() Around $60.00 for the compass and meter. The best combo money can buy. |
Gold Member Username: Ke5aqnIF I DONT KNOW THE ANSWER, I WILL FIND... Post Number: 2573 Registered: Sep-06 | ya but that meter is "ignorant" it does not ID the sat or have a quality meter for fine tuning...................i like the other one better not that i will ever get one i just use the fta receiver |
