I need 2 6x9 and 2 6-3/4" speakers... which way should I go?
Username: Grandhustle
Post Number: 40
I need to get 2 6-3/4" speakers for my door speakers and 2 6x9's for my rear deck and I'm not sure which ones to go with. I don't wanna be stingy on speakers because they are important.
For the 6-3/4"s I was thinking the Pioneer Premier TS-D701P. They seem pretty good and I can get them for like 100 bucks. Not bad but kinda cheap for good speakers no?
The 6x9's I was gonna go with the Alpine SPR-69c's. Anybody have any better suggestions or experience with these speakers? If you know of anything better, lemme know! Thanks
Post Number: 41
Forgot to mention, I have an 08 Chrysler 300 and I listen to rap music. Im running 2 Type R's for my subs and I have an amp running to my speakers.
Also, should I get component or coaxial?
Username: Exige
Post Number: 35
forget about the rears...you can barely hear them anyways. spend more money on the fronts. also, get components. CDT makes some real nice stuff. if you're interested PM me.
establish a budget for yourself. what kind of sound do you like...bright, mellow, etc? what speakers have you heard before? any high-end shops in your area? if so, check out what they have and listen to some sets to see what you like. lastly, what amp do you have?
