Polk Audio sub question?
Username: Polkaudio
Norwalk, OH USA
Post Number: 9
Ok I know I want to buy Polk Audio sub(s), I just like Polk Audio all around it may not be the best but it works.
I either want to get 2 Polk Audio MM2104 10"s(300w RMS 600w Peak 4ohms each), or 1 MM2124 12"(400w RMS 800w Peak 4ohms), or 1 MM124 12"(500w RMS 1000w Peak 4ohms)
I was wondering what amp I should get for any of those subs? and also what type of enclosure would get the best sound out of the sub(s)?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 957
I would do the one 12 with 500w. In that case, find an amp that does 500w RMS at 4 ohms like a cheap Kicker KX500.2.
As for a box thats up to you, but I like sealed boxes.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 958
My bad, you'd need the dual 4 ohm coil for that amp.
Username: Polkaudio
Norwalk, OH USA
Post Number: 10
Ok so if I went with the Polk Audio MM124 12" would any of these amps be good for it? I don't know much about what is a good company for amps and which is not.
U.S. AMPS XT800.2 XTERMINATOR AMP
or
POWER ACOUSTIK OV2-1250 2-CH 1250W
or
SONY XM-1652Z 1000 WATT
or
KENWOOD KAC-X522 AMP
What is everyones opinion on these amps? and will any of them work for that sub?
Username: •cam•
BC Canada
Post Number: 1409
Stay away from all those, except maybe the US Amps. Their quality seems to be up in the air. I have experience with eD and they're great IMO. A b-stock NINe.1 would be about right.
http://www.edesignaudio.com/edv2/product_info.php?products_id=372
