Ariza700 bin 308 no picture on bev
Username: Poochi425
Mis, On
Post Number: 77
i still have probs. with bev
as the latest fix bin 308 duznt show key id 0901
and only had 0904.
as per suggestion: i over wrt 0907 key on 0904
still rolled
then entered new 0901 on ffff spot
still rolling
i even rescanned the 82 but still rolling
can somebody help ??????
i badly wanna watch crckt on CBN
Username: Ke5aqn
Post Number: 2541
might study very hard your antenna settings
when you scanned did it get the correct channels?
Username: Tehrani
Iran, Tehran Iran
Post Number: 87
Turn on the receiver.
Press Menu on the remote
Select Parental Control
Enter i2004 as the pin
Go down to Key Menu
Leave the first option ON and change the rest OFF
Press Exit just once
Go down to Nagravision2 , press OK
Press down arrow to select Key Number 00
Press Down arrow to highlight Key Data
Enter new Key Data for Key No: 00
Key data 26 9F 38 F9 19 05 FC FA
5B 67 56 33 C1 19 AB FF
Press OK button on remote to store and save the changes
then go to Key Number again and by pressing right button just once
change it to 01
Enter new Key Data for Key No: 01
Key data D2 93 21 BC 7F DF 23 01
62 D3 CA 81 03 15 E9 27
Press OK button on remote to store and save the changes.
Now press EXIT until you see the picture. (Exit completely out of the menu)
Username: Tehrani
Iran, Tehran Iran
Post Number: 96
Benazir Bhutto killed in bombing Dec. 27: A suicide bombing at a political rally kills Pakistani opposition leader Benazir Bhutto. NBC's Jim Maceda reports.
